Colpatben Posted April 2, 2018 Share Posted April 2, 2018 First and foremost I am an N Gauge modeller who is starting to ‘Experiment’ with basic automation.I have an Elite controller and a track plan using Kato track and Turnouts.I have downloaded the evaluation version of Railmaster V1.68 for practice and have placed an order with Hattons for an R8144 CD that I assume will have the licence activation key.Why it is Railmaster only £5.00, are Hornby (or Invicto Systems Ltd.) no longer going to support it?My Layout needs two Auto Reversers so I have also ordered again from Hattons 2 No. R8238 DCC reverse loop control module at £12.00 each.Again why are they so cheap as I have read that they work well, but that they are a discontinued product. Is there an imminent replacement or are Hornby abandoning this sector of the DCC market?Notwithstanding the above I expect that in their current (relatively cheap form) this combination will work tolerably well. My biggest problem and the one I most need the answer to is to find a suitable accessory decoder to operate the Kato inbuilt Bi-polar solenoids.For those uncertain as to what this means, Kato Turnout have a bi-polar solenoid operate by applying a single pulse 12v DC supply +ve / -ve for Normal Operation and this supply is a reversed single pulse –ve / +ve for Thrown Operation i.e. 2 wires only and the polarity reversed. Kato recommend NOT to use a CDU.Now the majority of Turnout motors and hence accessory decoders work on 3 wires either energising two solenoids one for Normal and one for Thrown using a CDU for extra ‘Oomph’. Or reversing slow action motors such as Tortoise.So this rules out the Hornby R8247, interestingly this is not so heavily discounted so I hope that Hornby is not going to completely abandon DCC controllers.One option that is mentioned elsewhere on the Forum is the DCC Concepts ADS8fx and the 3 wire to 2 wire adapter, any comments or other suggestions? Link to comment Share on other sites More sharing options...
96RAF Posted April 2, 2018 Share Posted April 2, 2018 This is previous discussion on the subject https://www.hornby.com/uk-en/forum/newby-on-the-block/?p=1 Have a look at this fairly old external thread but no doubt the kit is still available. http://www.jnsforum.com/community/topic/2935-dcc-control-of-kato-unitrack-points/ And there is this http://nrmrc.org/sites/default/files/publications//electrical_control_of_unitrack_turnouts.pdf Then its a case of looking to see if RM supports those acc decoders.Rob Link to comment Share on other sites More sharing options...
westernwill Posted April 2, 2018 Share Posted April 2, 2018 I run both OO and N gauge layouts using RM/Elink and RM/Elite with KATO track and points. I use the Digitrax DS64 point decoder for all my points and they work perfectly with Elite and Railmaster/Elink. Easy to set up as they are the self-learning type so you can set the addresses away from where you need them and then just wire up. According to the documentation they can also operate from a booster although I have found no need for this. Link to comment Share on other sites More sharing options...
westernwill Posted April 3, 2018 Share Posted April 3, 2018 I also have 4 of the Hornby Reverse Loop Modules, 2 on each of my layouts and they work absolutely fine. Link to comment Share on other sites More sharing options...
Chrissaf Posted April 3, 2018 Share Posted April 3, 2018 Just to point out that the DCC Concepts DCD-SDC 3 wire to 2 wire convertor. Is a fairly basic circuit and should work with any 3 wire solenoid based Accessory Decoder (as long as it is common positive - I can't say that I have ever come across an AD that wasn't common positive). Thus if you already have 3 wire decoders, you can use the DCD-SDC without having to purchase a DCC Concepts ADS8fx decoder..Extract below from the DCD-SDC product pages on the DCC Concepts web site..The SDC is a clever wee device that takes the outputs from a 3-wire accessory decoder and turns them into a 2-wire reversing DC decoder, allowing you to use most solenoid accessory decoders to power Kato, Cobalt or other brands.Note: if using the DCD-SDC convertor to drive a 'stall' type point motor, then you will need an Accessory Decoder with a configurable output on time (preferably with an 'always on' option) such as the Hornby R8247. Link to comment Share on other sites More sharing options...
