Lemmon Posted May 9, 2018 Share Posted May 9, 2018 I have had my Network Rail HST for a few years and i have installed 2 DCC Chips (One in each car) and plan in getting sound when they are released. I had removed the body shell of the dummy car to add electrical tape to keep the wires for the decoder out of sight and to insulate it, I replaced the shell and put it on the track. I pressed F0 (the lights) and discovered the dummy car tail lights, headlights and cab lights were not working. Is there a way to solve this issue? Sound decoders: (https://www.hornby.com/uk-en/shop/power-control/tts-sound-decoders/twin-pack-tts-sound-decoder-class-43-mtu.html) Link to comment Share on other sites More sharing options...
Chrissaf Posted May 9, 2018 Share Posted May 9, 2018 Before you opened up the car to add the additional insulation tape did it all work OK?.It's one thing to chase a fault where something used to work and now doesn't, as opposed to something that has never worked after installing the decoder..Do the lights rely on sprung contacts between the body and the chassis to make electrical contact. If so, have they been bent or put out of alignment (a common fault).. Link to comment Share on other sites More sharing options...
Lemmon Posted May 9, 2018 Author Share Posted May 9, 2018 Chrissaf, The HST worked fine up until the point of me opening it and the connectors do not appear to be bent. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 9, 2018 Share Posted May 9, 2018 If it was me, I would be focusing my efforts on those sprung connectors. Many times I have seen sprung connectors that looked fine, but did turn out to be the culprit in the end. Link to comment Share on other sites More sharing options...
RDS Posted May 9, 2018 Share Posted May 9, 2018 Hi Lemmon and welcome to the Forum,Lights not working often means that the Decoder is connected the opposite way round, although you didn't say that you had unplugged it. Link to comment Share on other sites More sharing options...
Lemmon Posted May 10, 2018 Author Share Posted May 10, 2018 I have tried your suggestions but have had no luck getting the lights working. Any other thoughts? Link to comment Share on other sites More sharing options...
RDS Posted May 10, 2018 Share Posted May 10, 2018 If you are happy with all the connections as indicated by Chris, maybe it would be worth trying a different Decoder. I think it just has to be a process of elimination. Link to comment Share on other sites More sharing options...
96RAF Posted May 11, 2018 Share Posted May 11, 2018 I presume you managed to address both TTS decoders to the same address.A quick check if you have successfully readdressed all the loco is to try the lights on address 3 and if they work then the dummy car readdress didnt work.Rob Link to comment Share on other sites More sharing options...
2e0dtoeric Posted May 11, 2018 Share Posted May 11, 2018 Some decoders won't accept resetting unless they are connected to a motor!The work-around is to programme the decoder in the motor unit, then transfer it to the dummy, then fit another decoder to the motor unit and programme that. Link to comment Share on other sites More sharing options...
Sir TophamHatt Posted May 17, 2018 Share Posted May 17, 2018 What happens if the pins are bent and no longer reliable?Can you solder the wires straight to the pins and bypass the copper plate?My problem is the cab desk is loose so when pushing the chassis back in, the pins don't connect with the plates properly. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 17, 2018 Share Posted May 17, 2018 Can you solder the wires straight to the pins and bypass the copper plate?.Of course you can. But I suggest including a micro-connector in the wires for two reasons:.1) It allows the body to be more easily removed again if access is needed.2) The wires can be made shorter and more easy to hide if they don't need to be long enough to allow future body removal..These might make suitable micro connectors.http://www.expressmodels.co.uk/acatalog/Micro_Connectors.html. Link to comment Share on other sites More sharing options...
