RDS Posted May 15, 2018 Share Posted May 15, 2018 Hi, I run 6 gw Lima railcar but one of them keeps stopping for a second or two then off it goes I have a bus system track and all my other locos run fine including my hornby ones any ideas please as to the cause Thanks Link to comment Share on other sites More sharing options...
96RAF Posted May 15, 2018 Share Posted May 15, 2018 Depends who's decoder you have fitted, as some makes (not Hornby) have been reported recently as having a new ‘feature’ whereby if the track supply is interrupted the decoder stops the loco then brings it back to the original speed at whatever accelleration rate you have configured in CV3. Not everyone is happy with this feature.This may be what is happening to your Railcar.Rob Link to comment Share on other sites More sharing options...
Johnboy99 Posted May 15, 2018 Share Posted May 15, 2018 Thanks Rob they are Hattons 8 pin decoders Link to comment Share on other sites More sharing options...
jane1707819582 Posted May 15, 2018 Share Posted May 15, 2018 it is possible the decoder is shutting down detecting an motor overload ,what is the current rating of your hattons decoder ? can a higher value decoder be fitted and tested.can you measure the current of this loco ? perhaps service the motor ,could you have a loose connection on the pick ups /wiring .dirt on the wheels / track.perhaps swap decoders with one that "works ok " see if the fault moves ? Link to comment Share on other sites More sharing options...
96RAF Posted May 15, 2018 Share Posted May 15, 2018 Depending upon how old the Hattons clone decoders are then that may be a ‘characteristic’.Ask their live chat if it is a pucka feature of that decoder, but be aware they may blame your Hornby loco, Hornby controller, Hornby mother-in-law, etc.Rob Link to comment Share on other sites More sharing options...
Johnboy99 Posted May 15, 2018 Share Posted May 15, 2018 Right as I have so many of this model I am going to keep it for spare parts, so I will now look to buy a new hornby or dapol railcarthankyou. Link to comment Share on other sites More sharing options...
96RAF Posted May 16, 2018 Share Posted May 16, 2018 See post #8 herehttp://www.rmweb.co.uk/community/index.php?/topic/132447-decoder-at-fault/Send any dodgy decoders back and ask for a refund.Rob Link to comment Share on other sites More sharing options...
Sultan Posted May 16, 2018 Share Posted May 16, 2018 For this very reason I have now standardised on the Lenz Standard V2 decoder for fitting to Lima locos. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 16, 2018 Share Posted May 16, 2018 Re Jane’s suggestion, these decoders are rated at 1.1 Amps so should be ok. Worth doing a stall current test to check though. See Brian Lambert site for how to do this, you need an ammeter that will handle at least 2 Amps. Link to comment Share on other sites More sharing options...
Johnboy99 Posted May 17, 2018 Share Posted May 17, 2018 Thanks all, I am now ordering some 8pin zimo decoders,i think a lot of people have had probs with the Hattons onesThankyou. Link to comment Share on other sites More sharing options...
