VC Posted June 9, 2018 Share Posted June 9, 2018 I wonder if anyone has experience of adding aux1 and aux 2 light effects to the Oxford Rail Adams with Sound fitted? I decided to give ot a shot but it is very confusing to understand the Loksound Manuels The model comes with an ESU Loksound v4 fitted but there are no light or aux functions shown on the function list. Coal shoveling for example is F4 but Aux 1 did not come on when I wired an LED . I do not have the Loksound programmer but having read various V4 manuels I have ended up with AUX 1 as fire box flicker CV 275 on 4 but it works only on reverse on F0 and then only for 5 or 6 seconds unless I press F0 again. Aux 2 was not on either and in having a go to move it on the Aux 11 I have suceeded in turning it on F7 somehow and works both directions. F7 on the Adams is break squeal on/off not the ideal place for a cab light. Just wondered if anyone can explain how to map Aux 1 and Aux 2 for particular Function keys and to not have then only directional? Link to comment Share on other sites More sharing options...
96RAF Posted June 9, 2018 Share Posted June 9, 2018 Decoder Pro maybe a viable alternative method of reading and remapping your ESU decoder, but be aware it may be locked by Oxford against change. The ESU manual is a beast to wade through and comprehend but my first stop would be to ask Oxford. Decoder Pro users on here may be able to better advise on if it can do the remapping by ticking boxes rather than fiddling with CV values. Rob Link to comment Share on other sites More sharing options...
jane1707819582 Posted June 9, 2018 Share Posted June 9, 2018 cv 31 needs to be 16 cv32 needs to be 2 then lets try to switch aux 1 on with f0 using mapping controlcv 257 set to 16 cv 266 set to 4 if you want a different function button control let me know does this work ? Link to comment Share on other sites More sharing options...
jane1707819582 Posted June 9, 2018 Share Posted June 9, 2018 cv 275 needs to switch on cv 282 to a value of 4 this switches on aux 1 Link to comment Share on other sites More sharing options...
VC Posted February 11, 2019 Author Share Posted February 11, 2019 cv 275 needs to switch on cv 282 to a value of 4 this switches on aux 1 Hi Jane, I tried carious CV settings but not really moved it forward so have given up for now. I will probabtly need to buy a sprog and try readomg the CV's from my computerThank you for your advice howeverVC Link to comment Share on other sites More sharing options...
96RAF Posted February 11, 2019 Share Posted February 11, 2019 Thats why I suggested decoder pro.Rob Link to comment Share on other sites More sharing options...
Rog RJ Posted February 11, 2019 Share Posted February 11, 2019 cv 275 needs to switch on cv 282 to a value of 4 this switches on aux 1 Hi Jane, I tried carious CV settings but not really moved it forward so have given up for now. I will probabtly need to buy a sprog and try readomg the CV's from my computerThank you for your advice howeverVC If you have an Elite you don't need to buy a Sprig. The Elite can be used with Decoder Pro instead. Link to comment Share on other sites More sharing options...
Fireman_Ian Posted February 12, 2019 Share Posted February 12, 2019 You still need a sprog, the Elite will only write cv's from decoder pro, it cannot read them back. Link to comment Share on other sites More sharing options...
96RAF Posted February 12, 2019 Share Posted February 12, 2019 I have never had any problems populating a decoder entry using an Elite and D-P. Link to comment Share on other sites More sharing options...
VC Posted February 14, 2019 Author Share Posted February 14, 2019 Yours the brains of the organisation, thank you Rob it's on my next decoder shopping list, as i have similar issues with another Oxford Rail Adams Radial where i fitted the sound myself. I also wrote to them but heard nothing, ditto Loksound s Thats why I suggested decoder pro.Rob Link to comment Share on other sites More sharing options...
