MarsdenHall Posted July 4, 2018 Share Posted July 4, 2018 Hi, I was wondering if anyone else is a user of the Digitrax system and has this problem. I have 2 x Class 31's, 1 x Class 40 and 2 x Class 9F's that occasionaly without any prompting suddenly start moving without any throttle commands. The Hornby TTs decoders are the only ones that have this behaviour and I run Digitrax and Loksound decoders as well and they dont have this problem. I dont run DC on the system.Looking forward to any suggestions Peter Link to comment Share on other sites More sharing options...
96RAF Posted July 4, 2018 Share Posted July 4, 2018 I have seen this behaviour whilst programming, using all Hornby kit; whereby 4 of 6 TTS fitted locos on the main have either shot off, or started their engines or flashed their lights. At that stage I did not have bus terminators installed and to date although I now have the parts I still have them to fit. Not much help I know but it is not unknown. I put it down to a spurious DCC signal coming out of the Elite/Select when programming, which is why there have been previous recommendations to disconnect the main completely when programming. Rob Link to comment Share on other sites More sharing options...
MarsdenHall Posted July 4, 2018 Author Share Posted July 4, 2018 Hi Rob,Thanks for your thoughts. I will post onRMweb to see if anyone else has similar problems and more importantly, is there a fix? Peter Link to comment Share on other sites More sharing options...
MarsdenHall Posted July 4, 2018 Author Share Posted July 4, 2018 I have been looking at the Hornby TTS manual and I will have to check my units tomorrow but I wonder if the default value for CV29 needs to be changed.This is what the manual says "Bit2 (Add 4 to activate) is used to control whether the decoder will operateon both DC and DCC layout control. By default both forms of power are enabled. It is recommended if only running on a DCC controlled layout to turn off DC operation, i.e. CV29 = 2 if only changing this feature of CV29." Peter Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 4, 2018 Share Posted July 4, 2018 Peter, you are referring to DC Runaway which can be eliminated by turning it off in CV29 as you’ve suggested. But it causes a loco to take off flat out, not just low speed, and can only be stopped by removing power from the layout. Does that sound like the movement you have, or not. It’s not the movement while programming Rob is referring to. One thing I’d be doing is contacting HCC to see if your decoders need firmware upgrade, without which they may act strangely with non-Hornby controllers. Link to comment Share on other sites More sharing options...
96RAF Posted July 5, 2018 Share Posted July 5, 2018 I agree with Fishy, arrange with Hornby to have the decoders PIC code updated then you can be sure of a level playing field.Rob Link to comment Share on other sites More sharing options...
MarsdenHall Posted July 6, 2018 Author Share Posted July 6, 2018 Hi Rob and Fishman,All of the decoders were set for DC and DCC so I have changed all to DCC only. I have had the locos sitting on the layout with power on and so far no movements.I like the idea of checking with Hornby about having the firmware but being 12,000 miles away is a problem but I will contact them to see what they say. PeterPS Fishman, where in Oz are you? I am in Hastings, Vic Link to comment Share on other sites More sharing options...
MarsdenHall Posted July 6, 2018 Author Share Posted July 6, 2018 I have sent an email to Glen Richardson at Hornby as he handled my faulty Class 31 TTS cecoders last year Peter Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 6, 2018 Share Posted July 6, 2018 Hi Peter, enough with this formality, call me Fishy please, everyone else does. And not not quite near you, over the border in Sydney. Link to comment Share on other sites More sharing options...
MarsdenHall Posted July 10, 2018 Author Share Posted July 10, 2018 Hi Rob and Fishy,Well changing CV29 to DCC only does not work on a Digitrax system so another email to Hornby to see if there is a fix Peter (The Mexican) (An Aussie joke for Fishy) Link to comment Share on other sites More sharing options...
pendeenpete Posted July 15, 2018 Share Posted July 15, 2018 Just to add my experiences with TTS and my system which is Roco. I have three TTS locos,and when on the layout together will sometimes display the same symptoms. I have some points that isolate sidings,and when two of the three are isolated,no problems.The worst culprit seems to be the class 37,it can flash its lights,move off on a jaunt along the track etc.I have just come to accept the limitations of the TTS decoders, I think Hornby had to compromise on quality to keep the price down, adds a bit of humour to my layout though. I also find if I am programming one of them on the main,one of the others will react in some way. My Gadwall ended up in the well of my turntable for instance. Link to comment Share on other sites More sharing options...
96RAF Posted July 15, 2018 Share Posted July 15, 2018 Just to add my experiences with TTS and my system which is Roco...My Gadwall ended up in the well of my turntable for instance.Snap......been there, got the Tee shirt. Class 56 TTS in the well after a programming session ended up with several runaways, awry behaviour.Rob/media/tinymce_upload/4ed185c83d836e47ba9b7b82ba161262.jpg Link to comment Share on other sites More sharing options...
MarsdenHall Posted July 19, 2018 Author Share Posted July 19, 2018 After a week of testing my decoders via Hornby support and not getting anywhere, I have now been given a Job Number and tomorrow my decoders will be heading north for some sunshine and a firmware upgrade. Peter Link to comment Share on other sites More sharing options...
MarsdenHall Posted August 11, 2018 Author Share Posted August 11, 2018 Aftre a 2 weeks holiday in sunny Kent my decoders came home for the winter. The Class 40 had its firmware updated and now OK. The Class 9F Crosti was replaced and now OK so the trip was worth it. Peter Link to comment Share on other sites More sharing options...
