Tomaso60 Posted September 2, 2018 Share Posted September 2, 2018 Hi GuysHope this is the correct area to raise this. I have a Bachmann Class 108 which uses an ESU LokSound V 4.0 chip. I have it set to address 108 on CV 1 which works with my Lenz set including all sound CV's but does not work on my Elite updated to version 1.44 or with my Railmaster Pro. I don't know if it worked with the Elite on any version before the 1.44 update as I have only started to use it with the Railmaster Pro which I couldn't get to work with the Elite before, until I found the answer to my issue on this forum I'm taking it that there is a problem with the Elite reading the LokSound chip as I have other loco's on addresses above 99 which work without any problems.Hoping someone can help please.Tom Link to comment Share on other sites More sharing options...
96RAF Posted September 2, 2018 Share Posted September 2, 2018 There is absolutely no reason why Hornby kit should not control your decoder on that address as Hornby used to use those chips in their full fat sound locos. RM-Pro will control your loco via the Elite as long as you have registered it in the RM loco list. 108 is officially a short address lodged in CV1. Try a read back of this CV using the Elite Menu - read address selection. Also check that CV29 is configured for a short address because the loco will only respond to either a short or long address as directed by CV29. Read the decoder in RM and tell us what it reports. Rob Link to comment Share on other sites More sharing options...
Chrissaf Posted September 2, 2018 Share Posted September 2, 2018 Every single one of my locos are Loksound V4.0 except for one of them which is a V3.5. I have Elite on firmware 1.44 and use RailMaster 1.69.2.I do not have and never have had any issues whatsoever programming and controlling my Loksound equipped locos with my Hornby controllers..Did you by chance do your initial loco decoder configuration using the Lenz controller. If you did, my suggestion to you would be to factory reset the decoder (write 8 to CV8). Then re-program using the Hornby system. Hopefully this would get it working on the Hornby kit, then test the operability of the now Hornby configured decoder on your Lenz. Link to comment Share on other sites More sharing options...
Rog RJ Posted September 2, 2018 Share Posted September 2, 2018 I agree with Chris, reset the decoder. I'm fairly sure I've heard of this problem occuring after being used/programmed on another system. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 2, 2018 Share Posted September 2, 2018 All my loksound decoders work fine with my Elite, so it must be as suggested, Reset, and try again using a Hornby controller. Link to comment Share on other sites More sharing options...
Tomaso60 Posted September 3, 2018 Author Share Posted September 3, 2018 Hi guys Many thanks got it working , however it will work on the Elite and Railmaster Pro but not on the Lenz system. I can have one or the other but not both. Its amazing how the blatantly obvious sometimes escapes you. Tom Link to comment Share on other sites More sharing options...
Tomaso60 Posted September 3, 2018 Author Share Posted September 3, 2018 Hi guysIs the Elite NMRA compliant these days I know it wasn't when it was brought out initially. Tom Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 3, 2018 Share Posted September 3, 2018 As far as I know, it is, Tomas, the Select is a bit iffy. Link to comment Share on other sites More sharing options...
96RAF Posted September 3, 2018 Share Posted September 3, 2018 Hi guysIs the Elite NMRA compliant these days I know it wasn't when it was brought out initially. TomThe Elite was fully compliant as of v1.2. Is the Lenz kit firmware fully updated.Rob Link to comment Share on other sites More sharing options...
Tomaso60 Posted September 3, 2018 Author Share Posted September 3, 2018 Hi guysGot the 108 working now on the Elite and Railmaster, still won't work with the Lenz system though, but you can't have everything though. Will keep trying and let you know if I resolve the issue.Tom Link to comment Share on other sites More sharing options...
Rog RJ Posted September 3, 2018 Share Posted September 3, 2018 The only reason I can think of which might possibly be causing this is that one of the two systems is treating the address as a two digit address and the other is treating it as a four digit address, but AFAIK address 108 should be a 2 digit address on both. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 3, 2018 Share Posted September 3, 2018 That shouldn’t be the case given NMRA compliance of both systems (I’m assuming, not stating it to be fact). However, easy to check, try with a 2 digit short address and see what you get. Or you can just check CV29 with each. Is it set for short addresses on one and long on the other? The value should be the same on each but if one is 32 higher than the other, that one is set to long addresses. Link to comment Share on other sites More sharing options...
Tomaso60 Posted September 7, 2018 Author Share Posted September 7, 2018 Hi GuysJust as a follow up to the previous posts I have now resolved the issues that I had running the 108 with Railmaster and the Lenz kit. I eventually took the easy option and changed the CV1 address from 0108 to 0018 and now it works with both systems. The reason for wanting to use both systems is that if I want to have a session where I just want to see trains running on there own I use the Railmasteer on a Scheduling programme and sit back and watch them run. If I want a running session where I control the trains manually I use the Lenz on Traincontroller which runs the routes and drive the trains manually so I get the best of both worlds. However many thanks for you help and assistance with the advice and as I said in an earlier post sometimes the blatantly obvious escapes you until someone points this out to you and it's at that point you have a Homer Simpson moment and just think "DOH"Cheers everyoneTom Link to comment Share on other sites More sharing options...
Chrissaf Posted September 7, 2018 Share Posted September 7, 2018 Good to hear you got it working. An interesting solution, particularly that 0108 is technically still a 'short DCC address'. Short addresses are in the range 0001 to 0127. Hornby controllers treat 0001 to 0127 as being 1 to 127, in other words the leading zeros are ignored. Maybe your Lenz sees 0108 as being a four digit address, but is happy with a three digit 018. It does seem to appear that maybe your Lenz system could benefit from any firmware upgrade that might be available. Link to comment Share on other sites More sharing options...
Rog RJ Posted September 7, 2018 Share Posted September 7, 2018 I said it was possibly a controller problem in my last post. See this dcc wiki https://dccwiki.com/Address_Range#NMRA_Address_Ranges especiallyEspecially the "Compatibility Issues" section and "DCC Systems and Addressing Ranges" Link to comment Share on other sites More sharing options...
Chrissaf Posted September 7, 2018 Share Posted September 7, 2018 Following the link that Rog(RJ) gave, I found this:./media/tinymce_upload/558bfd7659a813654e75b2403a54e44c.jpg.This would most likely explain why the Lenz does not like the 0108 (108) DCC address. Link to comment Share on other sites More sharing options...
