Shadow.Monk Posted September 24, 2018 Share Posted September 24, 2018 Hello! I would like to make my own stock box however I am unsure as to what type of foam/material is used to protect the models. If anyone could give me some info that would be helpful :)Also what is the best tool for cutting and is super glue good for gluing the foam to the bottom and sides of the tub o purchased? Many thanks! Link to comment Share on other sites More sharing options...
walkingthedog Posted September 24, 2018 Share Posted September 24, 2018 I cut thick foam with an old sharp carving knive. If it is thin I use scissors. Some foam can deteriorate and stick to plastic. Link to comment Share on other sites More sharing options...
Shadow.Monk Posted September 24, 2018 Author Share Posted September 24, 2018 Hi WTD.The type of box I have is an 8 litre tubaware box. Sticking to the plastic is fine as this is a permanent box, however I obviously don't want this to stick to the models. Any more advice is much appreciated :) Link to comment Share on other sites More sharing options...
walkingthedog Posted September 24, 2018 Share Posted September 24, 2018 When I mentioned sticking to plastic I was referring to the model. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 24, 2018 Share Posted September 24, 2018 If you meant Tupperware, I would be surprised if you can find ANYTHING to stick to it. It's a form of semi-flexible polypropylene. Epoxy will just flake off. UHU POR - MIGHT grip it, as might silicon adhesive, but I wouldn't guarantee it. (note I put grip, not stick!) Link to comment Share on other sites More sharing options...
Shadow.Monk Posted September 24, 2018 Author Share Posted September 24, 2018 Vent holes, got it!Perhaps just locos and stock wrapped in bubble wrap would be better in a tub box then? Or do you suggest another style of box to insert the foam? Cheers! Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 24, 2018 Share Posted September 24, 2018 Wrap in acid-free tissue paper first, or the bubble-wrap might bond to the plastic, over time.Acid-free tissue - go to your local ARTS and CRAFTS shop (No names, but you probably know where I mean!) Link to comment Share on other sites More sharing options...
Mallard203 Posted September 24, 2018 Share Posted September 24, 2018 Games workshop sell cases with inserts that can be adjusted to suit. You can store tanks etc in them as well as the figures, but they ain't cheap. Link to comment Share on other sites More sharing options...
