Chrissaf Posted October 14, 2018 Share Posted October 14, 2018 Railroad Class 47 TTS should run without problems on Select 1-amp supply.Rob Link to comment Share on other sites More sharing options...
RDS Posted October 14, 2018 Share Posted October 14, 2018 Dadadam posted: Hi,Thanks for quick response.The model number is R3393TTS Link to comment Share on other sites More sharing options...
RDS Posted October 14, 2018 Share Posted October 14, 2018 @Dadadam As Rob says, the TTS Loco does not fall into the category of an 'older' Loco and it suggests the problem lies elsewhere. Are you able to run other Loco's on your layout? Link to comment Share on other sites More sharing options...
2e0dtoeric Posted October 14, 2018 Share Posted October 14, 2018 How are you connecting the controller to the track?Disconnect the wires from the controller to the track, then turn the controller on . Does the controller still show overload?If notConnect the track wires to the controller, but disconnect them from the track. What happens? Link to comment Share on other sites More sharing options...
Chrissaf Posted October 14, 2018 Share Posted October 14, 2018 Check your power track / power clip connection from the Select to the track to make sure it is a DCC compatible one. DC Analogue power tracks / power clips have been proven to affect TTS locos more so than non TTS locos..If a power clip, open the cover and look inside for a component (either round or square) that is connected across the track connectors. If such a component exists (then the power connection is the wrong type for your DCC layout) snip it out with cutters and close the clip again. If a power track, the equivalent cover is located on the power track between the rails. Link to comment Share on other sites More sharing options...
RDS Posted October 14, 2018 Share Posted October 14, 2018 Hi DadadamWelcome to the Forum. Please let us know the Make / Model Number of the Loco as your post tends to suggest it is taking more current than the 1 amp the standard Select Controller can supply. A number of older Loco's do tend to demand a lot of current. Of course this may not be the case with yours if it is a modern Loco though but it could explain why it works on the shop system and not on your system. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 14, 2018 Share Posted October 14, 2018 Eric, one piece of info Adam’s dad did tell us is that the short occurs when the loco is put on the track. Taking him at his word, it isn’t a layout short caused by crossed power connections or reverse loops. Rather it’s the loco itself. Consequently, being new, I suggest it goes back to the shop. And just on recent discussion on informative thread titles, this one would be much better if it were something like - TTS Loco Causing Overload with Select Controller. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 15, 2018 Share Posted October 15, 2018 Hi I am new to model railways, I purchased new loco yesterday and cannot get it programmed.Each time I put it on track the Select controller shows the Overload Error message.I tried setting it up on a short test track as recommended on this forum, same result.I took it back to shop and it worked fine on his track.Any help would be most appreciated before I go back to shop again. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 15, 2018 Share Posted October 15, 2018 Thread title edited as per Fishy's suggestion. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted October 15, 2018 Share Posted October 15, 2018 Fishy - he also put that he took it back to the shop, and it worked fine on their test track - hence my thinking the fault is between the controller and the loco! Link to comment Share on other sites More sharing options...
Dadadam Posted October 15, 2018 Share Posted October 15, 2018 Problem fixed, went back to shop again and found a problem with decoder. Changed it working fine now.Thanks all for help. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 15, 2018 Share Posted October 15, 2018 Strange Eric, conflict of logic here, I wonder how it worked at the shop the first time? Link to comment Share on other sites More sharing options...
Chrissaf Posted October 15, 2018 Share Posted October 15, 2018 Maybe the first time at the shop it was on an analogue controller.......just a thought. Or maybe a DCC system with a much higher current power supply with a higher OL threshold. Remember he did say he has a Select, which infers the 1 amp supply. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted October 16, 2018 Share Posted October 16, 2018 Whatever. - - It's another item to add to the list of misbehaving TTS decoders! 😆 Link to comment Share on other sites More sharing options...
96RAF Posted October 16, 2018 Share Posted October 16, 2018 Or finger trouble - the most likely cause of many ‘problems’. Link to comment Share on other sites More sharing options...
Wobblinwheel Posted October 23, 2018 Share Posted October 23, 2018 I was going to say, the first time it went to the shop, It should have been tested for amperage draw. Very quick and easy ... Link to comment Share on other sites More sharing options...
