Triumph speedtriple Posted November 2, 2018 Share Posted November 2, 2018 Hi peopleIs there a way to ajust the volume on a TTS sound loco, either the CV or a F numberCheers Peter Link to comment Share on other sites More sharing options...
96RAF Posted November 2, 2018 Share Posted November 2, 2018 It tells you in the TTS manual in great detail including advising setting the master volume first and individual volumes as required.The master volume CV depends upon if its a steamer or a diesel and the imdividual CVs are as per the individual loco listing in the manual.Volume range is 0 off to 8 max with 4 default.Generally CV178 is master steam volume and CV180 master diesel volume, although it may be 182, can’t recall without looking it up.Rob Link to comment Share on other sites More sharing options...
Chrissaf Posted November 2, 2018 Share Posted November 2, 2018 Assuming of course that you have a controller capable of adjusting CVs. Elite or eLink for example. A Select can't currently do it, and No, there is not an F number you can use. Link to comment Share on other sites More sharing options...
Triumph speedtriple Posted November 2, 2018 Author Share Posted November 2, 2018 Thanks people, I use an elite so can play around with the cv's Cheers Peter Link to comment Share on other sites More sharing options...
