Mr Bassman Posted November 2, 2018 Share Posted November 2, 2018 Previuosly I have not had a problem, but I now find the controller will not accept a change of address neither will it change acceleration/decelleration commands. I have follwed all the procedures in the manual: single loco on track following explicitly the procedure in the manual, reset controller via CA command eg Stop button and < and > buttons; turned loco around as sugested in one reply, but nothing changes. Does this mean the controller is busted or is there something else I can do??There are three locos involed and all have factory fitted gaugemaster dcc decoders installed. N gauge locos.As stated earlier there was previously no problem. Link to comment Share on other sites More sharing options...
Mr Bassman Posted November 2, 2018 Author Share Posted November 2, 2018 Have found the problem myself. A sigle Graham Farrish loco using a Gaugemaster DC23 decoder can be reprogrammed but two Dapol loco's with creep tender moters using DC23 decoders cannot be reprogrammed. Therefor there is nothing wrong with the Select unit. Will post a separate question on this problem. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted November 3, 2018 Share Posted November 3, 2018 What's a creep tender motor? (or was that a way of getting past the profanity filters?) Link to comment Share on other sites More sharing options...
96RAF Posted November 3, 2018 Share Posted November 3, 2018 Some motors have been described as super-creep, presumably meaning they have very good slow speed control.Rob Link to comment Share on other sites More sharing options...
Yelrow Posted November 3, 2018 Share Posted November 3, 2018 Or need a service. Link to comment Share on other sites More sharing options...
