m0eoujohn Posted November 8, 2018 Share Posted November 8, 2018 hi how do I remove the body to fit a dcc chip as the instructions are not clear is there photos or something to show where the clips are Link to comment Share on other sites More sharing options...
walkingthedog Posted November 8, 2018 Share Posted November 8, 2018 Would be very helpful if you stated exactly what loco it is in addition to the R number to save us having to find out. 😆 Link to comment Share on other sites More sharing options...
96RAF Posted November 8, 2018 Share Posted November 8, 2018 You need the maintenance sheet that came with the loco. You may be able to find one in the downloads area if it is listed - not all are. generally spring the lugs either fron or back or sides, depending upon the actual model.There is also a guide to fitting DCC to these little 0-4-0 monsters in the DCC+ Installations Section of the main site.Rob Link to comment Share on other sites More sharing options...
Chrissaf Posted November 8, 2018 Share Posted November 8, 2018 This would appear to be the R3678 Model../media/tinymce_upload/3413daefac759b1f62bd7c112bc25327.jpg.If it is indeed your model, then this DCC conversion guide (as recommnended by Rob above) looks to be suitable.https://www.hornby.com/uk-en/hornby-dcc/decoder-installation-guides/standard-0-4-0-decoder-installation-guide/ .PS - Body removal is documented in Step 1 of the DCC conversion guide. Link to comment Share on other sites More sharing options...
Rog RJ Posted November 8, 2018 Share Posted November 8, 2018 Some versions of the 0-4-0 chassis models have a fixing screw that needs to be removed, some are just a clip fit. You have to check which version you have by looking at the instruction sheet that should be included with the model. Link to comment Share on other sites More sharing options...
m0eoujohn Posted November 9, 2018 Author Share Posted November 9, 2018 Would be very helpful if you stated exactly what loco it is in addition to the R number to save us having to find out. 😆The R number is in the title R3678 Link to comment Share on other sites More sharing options...
m0eoujohn Posted November 9, 2018 Author Share Posted November 9, 2018 This would appear to be the R3678 Model../media/tinymce_upload/3413daefac759b1f62bd7c112bc25327.jpg.If it is indeed your model, then this DCC conversion guide (as recommnended by Rob above) looks to be suitable.https://www.hornby.com/uk-en/hornby-dcc/decoder-installation-guides/standard-0-4-0-decoder-installation-guide/ .PS - Body removal is documented in Step 1 of the DCC conversion guide.Thank you that sort of helped what I can not see is where the clips are holding the body on Link to comment Share on other sites More sharing options...
Bulleidboy Posted November 9, 2018 Share Posted November 9, 2018 It's the Hornby Collectors Club Freebie 0-4-0 for 2018 members. Link to comment Share on other sites More sharing options...
olly Posted November 9, 2018 Share Posted November 9, 2018 Here's a link to the maintenance sheet https://www.hornby.com/us-en/downloads/view/download/item/165As it shows on the sheet you carefully use a flat blade screwdriver to release the front of the body by inserting the screwdriver in between the body and the cylinders to unclip them . Link to comment Share on other sites More sharing options...
