DJC78 Posted December 29, 2018 Share Posted December 29, 2018 Hi all new member here.i bought my son the 911 Le Mans ARC Air set for Christmas and he’s already managed to burn out the engine on one of the cars.does anyone know what engine I need to replace it? thanks in advance Dan Link to comment Share on other sites More sharing options...
woodcote Posted December 29, 2018 Share Posted December 29, 2018 Hi Dan - welcome to the forum! Wow, that's good going - sounds like the ew set has had plenty of use! The motor replacement for the in-line cars like the Porsche RSR is this one: https://www.scalextric.com/uk-en/shop/spares-accessories/motor-pack-in-line-with-10mm-shaft.html Motors don't last for ever, even with careful use. However, they do burn out quicker if the gears and axle aren't smooth, causing the motor to work harder and heat up. It's worth checking for hairs, carpet fibres and 'fluff' around the gear and axle - and removing any with some tweezers - you'll need to remove the top of the car to do this. If the gear feels a little stiff when you turn the rear wheels by hand, then it's also possible the motor or axle bearing have been pushed up. When the body is off is a good time to have a look and push them back. Likewise, it's a good opportunity to add a drop of oil to the gear and to each of the rear axle bearings. There should be more info and diagrams in the set instructions on how to do all this. Hope that helps. Link to comment Share on other sites More sharing options...
DJC78 Posted December 30, 2018 Author Share Posted December 30, 2018 Thank Woodcote that’s great Link to comment Share on other sites More sharing options...
gorp Posted December 30, 2018 Share Posted December 30, 2018 Why do you think it is burned out ? Link to comment Share on other sites More sharing options...
DJC78 Posted January 3, 2019 Author Share Posted January 3, 2019 Why do you think it is burned out ?My son was holding down the car whilst car was trying to move. You can tell by the smell it’s burnt out.on another note, got the engine delivered today so now need to get myself a soldering set! Link to comment Share on other sites More sharing options...
