Gbh4 Posted January 6, 2019 Share Posted January 6, 2019 Hi I‘ve got lots of surplus trains that I want to sell but first I want to test them all to make sure they work ok. They are all analog dc but my setup is digital dcc. Basic question, but to test them is it just a case of disconnecting the wires to my elink and then connecting analog power to the track? Thanks Link to comment Share on other sites More sharing options...
96RAF Posted January 6, 2019 Share Posted January 6, 2019 As simple as that......disconnect the eLink and reconnect the analogue controller, or just connect a longish length of track to allow fwd/rev running.Rob Link to comment Share on other sites More sharing options...
Gbh4 Posted January 6, 2019 Author Share Posted January 6, 2019 Excellent, thought so but wanted to check with you fine folks first. Thanks for the reply. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 6, 2019 Share Posted January 6, 2019 If the o/p has any point-switching decoders, etc, fitted, would the dc analogue volts upset those?Also, any DCC fitted loco's on the track would have to have had their dc running option disabled in the cv's, or they would all take off at the same time, when the volts were turned up! Link to comment Share on other sites More sharing options...
Chrissaf Posted January 6, 2019 Share Posted January 6, 2019 If the o/p has any point-switching decoders, etc, fitted, would the dc analogue volts upset those?.Good point Eric, and so often overlooked.I would have thought a 3ft length of flexi-track is all you need just for testing and then the whole issue of DCC damage just goes away. Or consider a 'rolling road', then that investment could be re-couped due to it being usable for DCC loco testing too. Link to comment Share on other sites More sharing options...
Flashbang Posted January 6, 2019 Share Posted January 6, 2019 A piece of long'ish track and a new PP3 battery will do! Or just touch the PP3 across the locos pick up wheels and the motor should turn. Link to comment Share on other sites More sharing options...
