GWR 77 Posted February 13, 2019 Share Posted February 13, 2019 I have just hard wire a TTS S15 decoder into a Bachmann Nelson. all working ok but I have found that i have wired it so the run backward when it should be run forwards is the any way I can change this within the setting within the decoder to save me have to unsolder the motor. Link to comment Share on other sites More sharing options...
NormanQ4 Posted February 13, 2019 Share Posted February 13, 2019 @GWR 77Look at page 71 of the on line Railmaster Guide - Changing CV29 - Reverse direction.I haven't used it but it may solve your problem.I don't know why, but I've assumed that you areusing Railmaster. Link to comment Share on other sites More sharing options...
96RAF Posted February 13, 2019 Share Posted February 13, 2019 You can try amending CV29 as per this calculatorhttp://www.2mm.org.uk/articles/cv29%20calculator.htm This will also swap the lights functioning over to match but should not affect a steam loco as lights are not usually fitted. Link to comment Share on other sites More sharing options...
GWR 77 Posted February 13, 2019 Author Share Posted February 13, 2019 thanks all I will try this tonight And yes I am using railmarster Link to comment Share on other sites More sharing options...
96RAF Posted February 13, 2019 Share Posted February 13, 2019 thanks all I will try this tonight And yes I am using railmarsterThere is a tick box on the loco setup screen to reverse direction but that may be Pro only. Don’t have actual RM here to refer to. Link to comment Share on other sites More sharing options...
Chrissaf Posted February 13, 2019 Share Posted February 13, 2019 Yes, that is only a Pro feature. Extract below from RailMaster Pro feature list../media/tinymce_upload/eabab47a3aee923f2e91fba01c5f2e78.jpg Link to comment Share on other sites More sharing options...
