GWR 77 Posted February 21, 2019 Share Posted February 21, 2019 I have just fitted two locomotive with dcctts sound chips. When I put the loco on my test track l turn on the sound it canome on. But when I set the loco to run the wheel turn about an1/8 to1/4 revilution and stop, sound shuts off. I am run the system from railmaster. Which reads and seems to programs the decoder with no problem. I have clean the wheels and test track. This same problem has accurred with both loco one with a castle decoder and the other murchant navySHas anyone got any ideas as to what may be going on. Link to comment Share on other sites More sharing options...
96RAF Posted February 21, 2019 Share Posted February 21, 2019 Which make and model are these locos.It sounds like the decoder is struggling to cope with the motor load when you open the throttle.Did the locos run OK before you installed the TTS decoders. Did they have other decoders or were they DC previously. Link to comment Share on other sites More sharing options...
GWR 77 Posted February 22, 2019 Author Share Posted February 22, 2019 Both are Hornby , one ISA Hornby GWR 3800 2-8-0 DCC read the other is a Hornby southern West County Blackmore ValeI have had the Blackmore Vale working non DC l have converted it to DCC soundThe other ihave just got removed the decoder but did not check the it was running ok Link to comment Share on other sites More sharing options...
