Steveblakie Posted March 28, 2019 Share Posted March 28, 2019 Hi can anyone help I have the slightly older hornby points ( accessory) decoder R8216 , whilst trying to program it through railmaster its says something like this write only it doesn't allow you to read the cc,s I do have the newer version already up and running in the system ... I'm just trying to add this one also but struggling ! Regards steve Link to comment Share on other sites More sharing options...
Chrissaf Posted March 28, 2019 Share Posted March 28, 2019 Basically the R8216 is a factory defined single option Accessory Decoder. It only supports 100ms pulse (Solenoid Point) operation. Thus the only configurable feature is the DCC Address. Therefore it is also a 'write to only' device with no 'read CV' capability..Page 74 of the manual./media/tinymce_upload/53f50cf97384d47caf8599f79adab0b3.jpg.Page 73 of the manual./media/tinymce_upload/a3d77a08d323b1f20f1e8be84374357e.jpg.I would expect that in the pull down Accessory Decoder selection box (yellow highlight) you will find a R8216 option to select when configuring the R8216 (connected to the 'programming' track)..NOTE: For reliable configuration results, it is best to 'pre-charge' the R8216. Pre-charging involves connecting the R8216 to the main track (powered up) for about 30 seconds to charge up the internal capacitors. Then you move the R8216 briskly to the 'programming' track to set the DCC Address before the capacitor charge leaks away. If you try to configure the R8216 'straight out of the box' on the 'programming track' without this 'pre-charging' then the configuration attempt has a high probability of failing.. Link to comment Share on other sites More sharing options...
Steveblakie Posted March 28, 2019 Author Share Posted March 28, 2019 Thanks for your reply and yes it's in railmaster and did read somewhere that it needs charging up ! Did all that but still no joy !! .. I do only want to operate points with it but looks like I will have to buy another newer model !! The one i have works fine didn't realise there was such a big difference Link to comment Share on other sites More sharing options...
96RAF Posted March 28, 2019 Share Posted March 28, 2019 Try reading it as a loco and resetting it by writing value 8 to CV8 just like a loco decoder reset.You often have to charge the thing then try to program it several times just to top up the charge. Link to comment Share on other sites More sharing options...
Steveblakie Posted March 28, 2019 Author Share Posted March 28, 2019 Ok will try that thanks Link to comment Share on other sites More sharing options...
Steveblakie Posted March 28, 2019 Author Share Posted March 28, 2019 Thinking about it I bought both of these 2nd hand off Ebay and had to do the reset on the other one .. I had forgotten Link to comment Share on other sites More sharing options...
96RAF Posted March 28, 2019 Share Posted March 28, 2019 There is also using CV153 method, which I forget the details for but its in one of the manuals. Link to comment Share on other sites More sharing options...
Somerset Modeller Posted March 29, 2019 Share Posted March 29, 2019 What is the build number on the back, if it has 50/07 then it might be a R8247. There are alot of R8247 being old on ebay that are infact R8247. Hornby labelled them incorrectly. Link to comment Share on other sites More sharing options...
Steveblakie Posted April 1, 2019 Author Share Posted April 1, 2019 Hi still not got it working!! It as 05-07 on the box .. I have tried setting it up as both types .. I'm going to try the 08 cc reset again now ! Link to comment Share on other sites More sharing options...
