No need to cut the speaker down if he follows the instructions in my video.
If he sticks the speaker to the roof as far back as it will go (facing down) then when he puts the body back on it will clear the chassis. Ive fitted loads of HST’s this way.
I eventually got a reading back, 46 so yes it is a Hornby chip, but which one I still don't know! I guess i will just have to work my way through all TTS diesel instructions given the settings I found ie
1 startup
2 horn
3 horn
4 wheel squeal
5 accelerate
11 door slam
12 bell
13 whistle
14 beep
Thanks for your tips about the speaker, i will persevere and will make it fit - it came out so it must have gone in somehow.
Read CVs 7 Which will give the decoder firmware ID and whichever of these has a value 156, 157, 158, 159 (not all of them will be populated). These will give more clues as to the actual sound set and hence the loco.
Unfortunately my files are in transit, so I can’t get to read them until I locate the actual packing box they are in next week when it all arrives on my doorstep. No rush - we will get there in the end.
Tip - look to see if there are any fancy horns later in the function list as some TTS have some nice horn/whislte melodies. One shunter has a horn and a whistle (Answers on a postcard to JimmyJames our resident quiz setter).
96RAF
The decoder looks to be too small for a TTS.
if you notch the speaker casing it should fit that chassis step, then seal it with blak-tak for best accoustics.
Edit - maybe the speaker will stand on its side.
richard_croft
Richard
Ducking Giraffe
Thanks for that.
1 startup
2 horn
3 horn
4 wheel squeal
5 accelerate
11 door slam
12 bell
13 whistle
14 beep
Howbi
I guess that was a typo, DG, as the decoder code for Hornby is 48 not 46 ............. 😀...........HB
96RAF
