Carltonf Posted April 1, 2019 Share Posted April 1, 2019 Hi. I've a handful of TTS diesels and even fitted one to a ViTrains 37; But today, I've operated my latest acquisition - the J36 Maude with TTS fitted.I have a problem, or at least a query, as it might be a design feature. I tried to operate the engine, but nothing. Checked my wiring, tried another loco, and everything is working ok.I re-tried the J36 again, but nothing. Then I thought I'd try the sound function (F1), and the sound came on. Turned the controller, engine moves. Excellent. But when I turned the sound off, the engine won't move.So, the question is, is this by design - does the loco only move when the sound is turned on? Or is there a design fault, or even a CV setting? This is my first steam TTS, so maybe they are all like that? Link to comment Share on other sites More sharing options...
Howbi Posted April 1, 2019 Share Posted April 1, 2019 The loco should move throughout the speed range without sound.........what controller are you using?.........HB Link to comment Share on other sites More sharing options...
Carltonf Posted April 1, 2019 Author Share Posted April 1, 2019 What a "newb" as the kids say nowadays. I've sorted it - thanks for the reply howbiman, but it's by design. There is a setting (CV201) which controls the loco start delay. The default is 2.5 seconds, which I suppose, with sound on, is to get the relevant steam sounds going.I guess i am just impatient. But I am so glad it's not a fault, I hate sending things to be repaired! It's a beautiful loco and I don't want to part with it! Link to comment Share on other sites More sharing options...
Howbi Posted April 1, 2019 Share Posted April 1, 2019 That's great, Carlton, we all learn sommat new every day.........if you find the loco a bit jerky at low speed try changing CV150 to a value of 1..........HB Link to comment Share on other sites More sharing options...
Carltonf Posted April 1, 2019 Author Share Posted April 1, 2019 That's great, Carlton, we all learn sommat new every day.........if you find the loco a bit jerky at low speed try changing CV150 to a value of 1..........HBThanks again. It seems smooth enough, but will bear that in mind. Link to comment Share on other sites More sharing options...
96RAF Posted April 2, 2019 Share Posted April 2, 2019 CarltonAs you have found out there is a start delay setting, which is for the cylinders to blowdown before the loco moves. If you set this too low the loco will move sooner but the blowdown sounds will not have time to play out before it moves and it will look odd. Set it too long and the cylinders will blow twice (model dependant) or the chuffs will start before the loco moves, again looking very odd. Link to comment Share on other sites More sharing options...
