Towcesterj Posted June 16, 2019 Share Posted June 16, 2019 i have just received an 08 TTS sound module, the vol7me is very low even when it is outside the unit, I have tried to change the cv value but nothing changed, when I try and read the cv value it comes back as 255, I checked other values and they are all the same. I then looked at another unit with TTS and the values are all 255, I am doing someth8ng wrong? Link to comment Share on other sites More sharing options...
Chrissaf Posted June 16, 2019 Share Posted June 16, 2019 If you are directly attaching the TTS decoder 'black & red' wires directly to the controller programming output then be aware that you need to have a motor attached to a TTS decoder orange & grey wires before you can program it..All values being read as 255 means that your controller cannot electrically see the decoder. If it cannot see the decoder to read it, then it cannot see the decoder to write to it either i.e change volume levels..What DCC controller are you using?What firmware version has it got installed?How have you installed your 'programming' track piece......you are using a 'program track' for the other existing TTS loco you tried....I assume?.TIP: As this is your very first post, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button. Link to comment Share on other sites More sharing options...
Towcesterj Posted June 16, 2019 Author Share Posted June 16, 2019 The modules are installed in units with all wires connected, connected to my programming track which is a seperate setup to the main track. The units all work ok so movement and sound. I am using an elite controller with version 1.41 Link to comment Share on other sites More sharing options...
Phil_Spiegel. Posted June 16, 2019 Share Posted June 16, 2019 'Outside' the loco, the sound will always appear quiet because the air motion in front of anf behind the speaker cone mix freely - and cancel each othert out. One there is a baffle or enclosure separating front from back air, it will sound much louder ...... with the hornby 08, remove the front slatted grill and cut away the panel behind - then replace the slotted grill once the speaker is fixed / slotted into position behind the opening.(on the Bachmann version - the grill is not slatted, but solid - so I rebuilt the grill with slats on one of mine - otherwise very similar)As for whether you have successfully reprogrammed the sounds - the ear is the best judge 8-) - BUT if you have only tried the 'quickset' sound level adjustment (0-8), then it will always readback 255 regardless.Whilst some controllers seem to require 'readback' to continue programming, it is not the case with all, and most times I find it much easier to reprogram decoders without any readback .... why do I want to know, by the slow readback process, the previous number ? mostly I do not 8-) Link to comment Share on other sites More sharing options...
Chrissaf Posted June 16, 2019 Share Posted June 16, 2019 Just for clarity....when I wrote;"All values being read as 255 means that your controller cannot electrically see the decoder.".I meant ALL the CV's on the decoder, not just the ones relating to volume..Version 1.41 firmware was rushed out very quickly to fix bugs introduced in version 1.4.The current version is 1.44.......IMO it is worthwhile upgrading to the current latest version..If the volume is excessively quiet, then do give consideration to the TTS being shipped to you in a faulty condition. Very quiet volume that no amount of CV tweaking will fix is a known (fairly common) fault.. Link to comment Share on other sites More sharing options...
96RAF Posted June 16, 2019 Share Posted June 16, 2019 TTS volume default is midway - value 4 where 0 is off and 8 is max.Which CV are you trying to alter for master volume. Link to comment Share on other sites More sharing options...
Howbi Posted June 16, 2019 Share Posted June 16, 2019 The class 08 TTS decoder comes with a default sound value of 4 within a range of 0 - 8......the CV182 Quick Set volume does not give readback.........best to use CV161 and change to a max value of 8 which can subsequently be checked by a 'read'........HB Link to comment Share on other sites More sharing options...
96RAF Posted June 16, 2019 Share Posted June 16, 2019 Or using the Elite programming on the main facility to instantly adjust the master volume. If you cannot hear it change volume then it hasn’t done it. Link to comment Share on other sites More sharing options...
