KenTheFox Posted July 2, 2019 Share Posted July 2, 2019 So my Select needs upgrading because it a 1.v1 and I need to change some cv and get a bit more control. The new upgrade v1.16 lets you do that as I understand. But should i just get a new Elite instead I only run 2/3 loco at a time and only have 15 in total so do I need the extra I will get with Elite. I can only think of being able to control the Loco's when running 2 without having to keep switching back and forth which some times can get a bit confusing at times when I don't noicte it as reset to LA3.Any thoughts? Link to comment Share on other sites More sharing options...
96RAF Posted July 2, 2019 Share Posted July 2, 2019 You could update your Select to gain CV control and add another Select or several as Walkabouts in order to gain more throttles but if you ever want to use PC control then seriously think about upgrading your controller to Elite. Other make controllers are available. Link to comment Share on other sites More sharing options...
KenTheFox Posted July 3, 2019 Author Share Posted July 3, 2019 Thanks for your help. Can't see me ever wanting to run PC control it's only 8' x 5'6" but thanks for the advice think I will get another select and get update. Link to comment Share on other sites More sharing options...
