Coreservers Posted July 12, 2019 Share Posted July 12, 2019 Im at a point where in cabline up the layout.so i bought 6 digital power tracks. Ive also soldered cables to fishplates for additional power to sidings etc.the problem i have is keeping the cables in these power tracks. no matter how firmly the buttons are pressed the cables never seem to fit safely.anyone any advice.. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 12, 2019 Share Posted July 12, 2019 ....anyone any advice...Yes....don't use them.....keep with using soldered wires (but preferably direct to rail, not the joiners)..Are you using the official Hornby X8011 terminal pins (crimp and/or soldered) on the end of the wires that are pushed into the power tracks, or just bared wires. Bared wires are probably not rigid enough, and give way under the internal spring terminal which is designed to work with the X8011 pins../media/tinymce_upload/2fbc06ce24106992e6db626604612cd9.jpg. Link to comment Share on other sites More sharing options...
Coreservers Posted July 12, 2019 Author Share Posted July 12, 2019 i wasnt using the terminal pins. i use the fishplate solders but once attached i solder the joiner to therrtack to ensure a complete connection. Thanks very much.. great advice Link to comment Share on other sites More sharing options...
Chrissaf Posted July 12, 2019 Share Posted July 12, 2019 Good god no.....never ever solder the track joiner to the rail..The joiners (unsoldered) allow the track to expand and contract preventing buckling. You can probably get away with just the odd joiner here and there soldered, but never solder them all on the whole layout. Link to comment Share on other sites More sharing options...
walkingthedog Posted July 12, 2019 Share Posted July 12, 2019 If you are going to solder the rail joiner, as stated big mistake, you might just as well solder the wires to the rails. Link to comment Share on other sites More sharing options...
Coreservers Posted July 12, 2019 Author Share Posted July 12, 2019 Ill try that... tho definitely dont solder every joiner and only 1 side. was advice given.. but makes sense. Link to comment Share on other sites More sharing options...
walkingthedog Posted July 12, 2019 Share Posted July 12, 2019 If you can use a soldering iron then do a proper job. 😆 Rail joiners are just that, if you solder them they are very difficult to unsolder if you need to move the track, and you most certainly will need to do that. Link to comment Share on other sites More sharing options...
