Stokeyboy Posted July 25, 2019 Share Posted July 25, 2019 Hi all. Just need a piece of advice on the programming facility on the Elite. Need to set up a small piece of track to test two dcc locos I have recently purchased second hand. I have a digital track piece which I have never used which will be ok for one piece. Lots of wire available to me without buying anything special. What would you recommend to use as a stop gap facility. The thin lamp wire has been suggested at 5 amp capability. Any more suggestions would be appreciated. Cheers. Ps Have not set up my bus or droppers yet!!. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 25, 2019 Share Posted July 25, 2019 5 Amp wire is more than adequate and could be considered overkill. Programming current is greatly reduced by the controller compared to the running track output..The recommended track dropper wire is 7/0.2mm and rated at 1 Amp. So 5 Amp wire is as stated more than required. Link to comment Share on other sites More sharing options...
96RAF Posted July 25, 2019 Share Posted July 25, 2019 General guide is if it fits nicely in the sprung terminals then its good for the job. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted July 25, 2019 Share Posted July 25, 2019 A more informative title would help you to find it again later. Something like - Programming track wire. Link to comment Share on other sites More sharing options...
