ron 47 Posted August 19, 2019 Share Posted August 19, 2019 Hi all the E link will Program Locos but Locos will not Run but if you program a new loco to the old adress it program it ok. but then when i turn a E link back on the Loco is lost after saving it any one know what going on. Please Ron 47 Link to comment Share on other sites More sharing options...
KNAP Posted August 19, 2019 Share Posted August 19, 2019 How many locos have been programmed, as there is a limit before you have to use groups. Link to comment Share on other sites More sharing options...
ron 47 Posted August 20, 2019 Author Share Posted August 20, 2019 HI Knap yep that not the problem as locos that where on the E link when i had visiting locos come i have delete them. and this problem is still there.Ron 47 Link to comment Share on other sites More sharing options...
96RAF Posted August 20, 2019 Share Posted August 20, 2019 I have absolutely no idea what the question is. eLink does not store anything. RM is in charge of storing locos in its/(your) roster database. You not only have to tell RM what a loco and its address is but you have to program the loco decoder to that address, although it usually happens the other way around, you program a loco then list it in RM as that address (ID). Link to comment Share on other sites More sharing options...
ron 47 Posted September 4, 2019 Author Share Posted September 4, 2019 HI all to Sort out this problem my son has been on line and found that this is not just me having problem whit e link. he has now sorte it you need to start a new group in the loco list on the program side and put the tick in this sorted it all out and i can now program Locos hope this helps.Ron 47. Link to comment Share on other sites More sharing options...
Chrissaf Posted September 4, 2019 Share Posted September 4, 2019 Ron, this unfortunately is not new information. The need for groups to resolve this issue is a known workaround and documented in detail on this forum. Which is why KNAP mentioned it in his reply..For others searching for an answer, here are links to the relevant posts:.Grouping Locoshttp://www.hornby.com/uk-en/forum/grouping-locos-with-elink/?p=1.Grouping Locos to fix loco roster limithttps://www.hornby.com/uk-en/forum/railmaster-has-limit-on-the-roster-of-64-active-locos/?p=1/. Link to comment Share on other sites More sharing options...
ron 47 Posted September 6, 2019 Author Share Posted September 6, 2019 Hi Chrissaf thank you i did not see that. but at lest problem sorted.Ron Link to comment Share on other sites More sharing options...
