morairamike Posted August 20, 2019 Share Posted August 20, 2019 I have bought two 21 pin decoders in the past, one in a 2EPB and one in a 2BIL I've looked high and low for the instruction sheets but they must be somewhere safe. I am awaiting delivery of a Class 419 MLV which needs a 21 pin decoder. Have thought but amaybe Lenznyone any other suggestions. Cheers Link to comment Share on other sites More sharing options...
96RAF Posted August 20, 2019 Share Posted August 20, 2019 Depends upon what you need the decoder to do Mike. Basic functions, extended functions or sound. Lenz silver/gold or current equivalent are usually bombproof but Sapphire is a reasonable and capable if expensive alternative. You could chance your arm on a Zimo, DCC Concepts or even Hattons or Liais-dcc item. Link to comment Share on other sites More sharing options...
Howbi Posted August 20, 2019 Share Posted August 20, 2019 If it is the Bachmann 419 MLV the logical choice would be the Bachmann 21 pin decoder, it fits and works.........HB Link to comment Share on other sites More sharing options...
ColinB Posted August 20, 2019 Share Posted August 20, 2019 I used one of those cheap ones from EBay in my Bachmann Electrical Multiple Unit. In fact I have them in a few of my locos, the 8 pin ones seem a bit more "flaky". They all seem to work OK. I must admit I just want to loco to work with DCC, I am not into changing inertia curves etc.The 21 pin decoders seem to be a lot more robust than the 8 pin, because the way they connect to the loco is much better and better designed. With the 8 bin, with all the "flylng leads" it is much easier to short things out, plus a lot of times the supplier insulates the module but leaves two nice rows of tops of pins on the connector, to touch something they shouldn't. Link to comment Share on other sites More sharing options...
pd91223 Posted August 21, 2019 Share Posted August 21, 2019 I have a Dapol Imperium-1 in my Class 419 and also a couple of other EMUs. It works fine and is a reasonable price; just plugs straight in, no extraneous cables. Link to comment Share on other sites More sharing options...
morairamike Posted August 22, 2019 Author Share Posted August 22, 2019 I bought a Laisdcc 4 function. Not heard of them before but I hope to go sound on my 3 3rd rail EMUs later so the price was good.Thanks for the suggestions.My other 416 has I have now found a Lenz silver as I used the assymetric function on it, but new layout is different so not going that route. Link to comment Share on other sites More sharing options...
ColinB Posted August 22, 2019 Share Posted August 22, 2019 The Laisdcc was the one I was referring to. Both of my Bachmann Multiple Electric Units have one. Seems to work OK and very cheap. I am not sure it has current overload protection for the motor, but generally on reasonably new models it is not an issue. Link to comment Share on other sites More sharing options...
Sultan Posted August 27, 2019 Share Posted August 27, 2019 I use Lenz Silver 21 pin which has the best motor control but is a bit pricy at circa £30 http://www.coastaldcc.co.uk/products/lenz/silver-21pinDCC Concepts have a new Zen 218 Black which incorporates 'Brown- Out' protection ( an inbuilt form of stay-alive) and I will be trying one of these soon.http://www.coastaldcc.co.uk/products/dccconcepts/zen-black-zn218 These retail for under £25. Link to comment Share on other sites More sharing options...
