66griff66 Posted October 8, 2019 Share Posted October 8, 2019 how do you find the R number on older models .just dug 5 locos out of the attic need R number to order brushes and wheel bands. Link to comment Share on other sites More sharing options...
walkingthedog Posted October 8, 2019 Share Posted October 8, 2019 If you tell us what the locos are or post some pictures we may be able to help. Link to comment Share on other sites More sharing options...
RB51 Posted October 8, 2019 Share Posted October 8, 2019 Hi 66 - welcome to the forum. Please be aware that you are restricted to 2 posts in your first 24 hours on here - so use the next one carefully! Also any images you post will be held for moderation by the forum Admin. [not a Moderator] so could take a little while to show up on here. Please be patient and we'll get you all the help you need. R- Link to comment Share on other sites More sharing options...
66griff66 Posted October 9, 2019 Author Share Posted October 9, 2019 If you tell us what the locos are or post some pictures we may be able to help.All 1980-1990s ..........intercity swallow numberd43198.........intercity named Terrance cuneo. No 91-011..........railfright double red diamonds and Tudor rose .........green mallard ring filed in tender........looks like pandered peckett 0-6-0 armature with worm gear (red wire off on this one any idea where it attaches to) thanks for any help in ldentifing R numbers. Link to comment Share on other sites More sharing options...
Tony57 Posted October 9, 2019 Share Posted October 9, 2019 Class 91 R585Mallard R350 or R353Can you check HST number and need a bit more detail on other locos Link to comment Share on other sites More sharing options...
VESPA Posted October 9, 2019 Share Posted October 9, 2019 Have a look at this listing and the bogies section http://www.hornbyguide.com/service_sheet_menu.asp Link to comment Share on other sites More sharing options...
Going Spare Posted October 9, 2019 Share Posted October 9, 2019 Not quite sure what a 'pandered Peckett' is, but for the others they all use the same Ringfield motor brush - pack X8026 for 10 or X8466 also containing 10 brush springs. Traction tyres are packs X8029 (or later renumbered X8461) - small, and X8030 - large. Each pack contains 10 tyres. Small is for the HST and class 91 plus the Railfreight loco which is likely to be a class 37 or 47, whilst the large is for Mallard's tender.GS Link to comment Share on other sites More sharing options...
66griff66 Posted October 9, 2019 Author Share Posted October 9, 2019 Thanks for the information all sorted regards Link to comment Share on other sites More sharing options...
