Mark66 Posted October 29, 2019 Share Posted October 29, 2019 Hi,Note: New to Model RailwaysHow do I couple up a Castle class locomotive to its tender? I have what I think is called a drawbar sticking out of the loco but not sure how it attaches to the tender. It’s a C shape. There is also a screw under the tender.Help please....Thanks Mark Link to comment Share on other sites More sharing options...
atom3624 Posted October 29, 2019 Share Posted October 29, 2019 Be careful with the metal same-shaped contact to the plastic drawbar - see where it makes contact to the tender, line up, and simply push together. In doubt? Check out some YT videos - bound to be a few, but once figured out, it's very simple. Al. Link to comment Share on other sites More sharing options...
Lyd 85B Posted October 29, 2019 Share Posted October 29, 2019 What is the Hornby product number (beginning with 'R')? If you don't know, what is the name of the 'Castle'? Link to comment Share on other sites More sharing options...
Mark66 Posted October 29, 2019 Author Share Posted October 29, 2019 It’s a ”Winsor Castle” loco, which comes with the “GWR Western Pullman Digital Set. R1077 Link to comment Share on other sites More sharing options...
Chrissaf Posted October 29, 2019 Share Posted October 29, 2019 At a guess I would imagine that the C shaped bar clips firmly onto the vertical pole on the tender. It may be that the vertical pole has broken off, or the C bar is worn or the vertical pole is worn or both are worn, such that the C clip doesn't stay attached under tension load../media/tinymce_upload/78eb20befbe65c73191facbf14ea212a.jpg.PS - This is only a guess based on the drawing as I have not personally seen this type of coupling before. The drawing may help other's to recognise this coupling type and provide a more accurate reply..TIP: As this is your very first question, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..Particularly as my reply includes an image. If you use the blue button, any reply you write, may be held back for image approval. Even though it is already a previously published image..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/ Link to comment Share on other sites More sharing options...
SRmike Posted October 29, 2019 Share Posted October 29, 2019 I have a loco with this type of tender coupling. It is R3071 Nunney Castle. I was worried about this and so it stays connected and is either in a display cabinet or plastic box for transporting to run on my club layout Link to comment Share on other sites More sharing options...
96RAF Posted October 29, 2019 Share Posted October 29, 2019 If that was my loco I would be dismantling the tender until I could locate a complete closed link on the tender post and if needed in future disconnect at the loco screw making sure to keep tabs on that spring. Having such a snap on connection is against all my engineering principles. It doesn’t look as if there is any need to transfer power across tht link. Nice bit of picture fettling Chris, to bring all the bits closer for illustrative purposes. Link to comment Share on other sites More sharing options...
walkingthedog Posted October 29, 2019 Share Posted October 29, 2019 I've always found the connection to be very sound but once connected I rarely disconnect it. Link to comment Share on other sites More sharing options...
atom3624 Posted October 29, 2019 Share Posted October 29, 2019 As WTD, I had a few of these 'earlier type' Castles, and the connection was fine. As I said right at the beginning, just be very careful with the metal contact - a clumsy approach can fold it over as I found with one I had received. Al. Link to comment Share on other sites More sharing options...
Mark66 Posted October 30, 2019 Author Share Posted October 30, 2019 Thanks All!It was a simple case of a bit more force for the clip to attach to the Tender. I was being over cautious trying not to break it!Thanks again. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 31, 2019 Share Posted October 31, 2019 Mark,Thank you for the resolution feedback...it is much appreciated....not many new members do. Link to comment Share on other sites More sharing options...
walkingthedog Posted October 31, 2019 Share Posted October 31, 2019 I always thought the system worked very well although once connected it was best to leave it that way. Link to comment Share on other sites More sharing options...
