Red Rebel Posted November 15, 2019 Share Posted November 15, 2019 Can the 412P No.9 - Brands Hatch 1967 car be chiped ? and if so is it an easy task Link to comment Share on other sites More sharing options...
woodcote Posted November 15, 2019 Share Posted November 15, 2019 Hi Red Rebel - the Ferraris are not Digital Plug Ready (DPR), but they are easy to chip with the C7005 Retro-Fit digital chip (https://www.scalextric.com/uk-en/retro-fit-digital-chip-a-single-seater-type.html). The chip comes with full instructions and requires basic soldering skills to solder two wires to the motor and two wires to the guide plate. I hope that helps. Link to comment Share on other sites More sharing options...
Red Rebel Posted November 18, 2019 Author Share Posted November 18, 2019 Hi Red Rebel - the Ferraris are not Digital Plug Ready (DPR), but they are easy to chip with the C7005 Retro-Fit digital chip (https://www.scalextric.com/uk-en/retro-fit-digital-chip-a-single-seater-type.html). The chip comes with full instructions and requires basic soldering skills to solder two wires to the motor and two wires to the guide plate. I hope that helps. Link to comment Share on other sites More sharing options...
Red Rebel Posted November 18, 2019 Author Share Posted November 18, 2019 Yes it does thank you, I have fitted a few chips just wanted to know if it was possible for this car, Link to comment Share on other sites More sharing options...
Tomski199 Posted January 12, 2020 Share Posted January 12, 2020 /media/tinymce_upload/b655ce1733ca29df8af492745892332d.jpgHi thereit looks like it should be dead easy and there's even a predrilled hole for the LED.but... ive just tried to do mine, taking the red wire from the chip to where the yellow was on the motor, and the black to the green (Having unsoldered the originals). That seems to be the only electrical work needed from the instructions...my result in the track was a small pop, a slight burning smell and I think something on the chip has burnt out. Resoldered the originals and all is fine again in analogue mode...have I missed something?tiaTom Link to comment Share on other sites More sharing options...
Andy P. Posted January 15, 2020 Share Posted January 15, 2020 If the predrilled hole you are referring to is the one in front of the motor it is too far back for lap counting on ARC PRO. The LED should be as close to the guide blade as possible for accurate lap counting. Link to comment Share on other sites More sharing options...
woodcote Posted January 15, 2020 Share Posted January 15, 2020 Hi Tom. The green and yellow leads should go to the front of the car - to the guide plate and braids. I strongly suspect that the pop and burning smell was a component (or components) on the chip being destroyed by power being applied to the chip in the wrong direction. Although the instructions could be better (in colour, perhaps - or link to pictures and a video online?), the wires are labelled correctly. I suggest that you contact Scalextric Customer Services (details right or below) and see what they can do for you. I hope that helps. Link to comment Share on other sites More sharing options...
