6233 DoS Posted November 21, 2019 Share Posted November 21, 2019 Hi All, a technical question if I may. I have a 1980-81 Caledonian 0-4-0 Pug like the one below.http://www.hornbyguide.com/catalogue_images/1980_r057.jpgPossibly due to wear, perhaps due to previously dirty wheels and track (all clean now), the wheels arc with sparks and the rims are blemished and no longer smooth. Indeed a couple of flanges are chipped like the below (far wheel flange). Link to comment Share on other sites More sharing options...
walkingthedog Posted November 26, 2019 Share Posted November 26, 2019 So what is the question? Link to comment Share on other sites More sharing options...
Tony57 Posted November 26, 2019 Share Posted November 26, 2019 I would find a scrapped loco with a good chassis strip the wheels off both chassis and replace the damaged ones with good ones or just replace the bad chasssis with the good one if a perfect match ( there are 3 types of 040 chassis) or just buy a new chassis from New Modellers shop or Peters spares etc.,. the wheels are finished fit for a wagon load only. Link to comment Share on other sites More sharing options...
6233 DoS Posted December 16, 2019 Author Share Posted December 16, 2019 Hi AllTrying again as i had a problem uploading pictures:Hi All, a technical question if I may. I have a 1980-81 Caledonian 0-4-0 Pug like the one below.Possibly due to wear, perhaps due to previously dirty wheels and track (all clean now), the wheels arc with sparks and the rims are blemished and no longer smooth. Indeed a couple of flanges are chipped like the below (far wheel flange).So how best is it to fix? And how easy is it?Should I replace the whole wheels or just the tyres? Or is a new rolling chassis the best solution. The former is preferred but how easy is it to do?Pictures below and advice is gratefully received: /media/tinymce_upload/4f0e91cbdebd0b2d784f52703220c47d.jpg /media/tinymce_upload/94b62b7048d65022160c9154aa5ed4c5.JPG/media/tinymce_upload/cf303fb6508829e2b3fd652c0e12fedf.JPG Link to comment Share on other sites More sharing options...
96RAF Posted December 16, 2019 Share Posted December 16, 2019 It is easier just to replace the whole motor and chassis As they are relatively cheap and much less hassle than trying to replace wheels sets. The damage to those wheels by the way looks like corrosion, probably from being stored for a long time in dampish conditions. Scroll down this page to find Motor-Chassis for the 0-4-0. Compare your chassis with those on service sheet 200 as there are several variants with different cylinders, etc. https://www.newmodellersshop.co.uk/hornby_spares_motors_and_gears.htm You can also try Peters Spares and even Hornby but watch out for heavy postage charges. Link to comment Share on other sites More sharing options...
VESPA Posted December 16, 2019 Share Posted December 16, 2019 I think that this is the norm for this model as it is the cheapest in the range. I doubt many others will be any different. The "corrosion" looks just like bad casting as it is under the chrome from what I see in the photo. Link to comment Share on other sites More sharing options...
JJ73 Posted December 17, 2019 Share Posted December 17, 2019 WOW - That wheel that you have circled - the flange bit almost looks flat!!! Taking things apart is easy - now putting thing back together - now that's the challange!!!/media/tinymce_upload/b5df7f2538d5b8d1b2d8457d496e9f05.JPG I think that if you want to take the body off the Chassis - the middle screw is to hold the motor on & the left screw is to hold the body on (might be clip on 1 end as well - don't ever force something it it won't go - don't want to break it!!!) Link to comment Share on other sites More sharing options...
6233 DoS Posted December 17, 2019 Author Share Posted December 17, 2019 yes there are a couple of areas where the flange is flat and indeed in places quite spikey sharp. On running, sparks arc between the wheels and the track which also causes blemishes / scorch marks on both surfaces. I suspect that this arcing weakens the metal flanges too. Amazing what even low power electricity can do...! Link to comment Share on other sites More sharing options...
6233 DoS Posted December 17, 2019 Author Share Posted December 17, 2019 And thank you RAF96 for the chassis replacement - they aren't expensive as you say. And perhaps a new one will be differently geared - my one is far too quick and easily gets wheel slip as the increase in power from the motor is not linear. Wheel slip can also cause excessive wear too, of course.But it will be a bit of a Triggers Broom now...! Link to comment Share on other sites More sharing options...
walkingthedog Posted December 17, 2019 Share Posted December 17, 2019 Think you'll find it will still be too fast. Link to comment Share on other sites More sharing options...
