Lowey Posted December 29, 2019 Share Posted December 29, 2019 Should my hornby select be left switched on all the time.When i turn it off at the mains i have to reprogramme all the loco's again.Thanks for any advice for a novice Link to comment Share on other sites More sharing options...
Rog RJ Posted December 29, 2019 Share Posted December 29, 2019 No. Never leave it unattended while it is powered up. There is always the very slight chance that a fault could develop on any electrical equipment (eg tumble driers and washing machines!) that could be disastrous. The decoders should not need to be reprogrammed when power is disconnected. Link to comment Share on other sites More sharing options...
Chrissaf Posted December 29, 2019 Share Posted December 29, 2019 If when you say:.When I turn it off at the mains I have to reprogramme all the loco's again.....You mean that you cannot repeatedly press the 'Select' button to call up a previously used loco from the Select internal memory until you have selected that particular loco's DCC address again. This is not the same as 're-programming the locos', which is a term used when changing CV functions on the loco decoder. Hence, Roger's last sentence comment, where he has taken what you have written quite literally..Then NO, you cannot permanently lock (store) the loco DCC address into the Select memory. This memory is 'dynamic' and designed to function in the way it does. You are trying to use it as a feature that it was not designed for, nor its operational intended use..This is a question that has been asked before regarding the correct use of Hornby DCC controller memory. The Hornby Elite memory operates in the same dynamic manner too..TIP: As this is your very first post, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
96RAF Posted December 29, 2019 Share Posted December 29, 2019 To sdd to what Chris has said. The locos have not lost their address, it is held firmly in the decoder, so as soon as you ask the Select to run loco X then it will, without any need for ‘reprogramming’. What the Select and many other controllers conveniently do is remeber which locos have run in a session and keep them in a recall list for you. Link to comment Share on other sites More sharing options...
