Exetersteam Posted January 5, 2020 Share Posted January 5, 2020 Having just upgraded to Railmaster Pro I have an issue on start up. It is not setting the points as the old system did on start up. My layout is 30ft long and has over 50 sets of points so checking it all manually is a bit of a faff. I have raised this with HRMS but in the meantime does anyone have any ideas on how to fix this? Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 5, 2020 Share Posted January 5, 2020 Hi, I don't think there is an easy way other than to go into the layout designer and select those points which you want to set at startup, and for each one allocate it a non-zero startup sequence number. It may be that you don't need to set every point on startup for example, you might only need to set those on the main line, but not those in the sidings. The only alternative way is to create a program containing a list of point switch commands, again for those points you want to set, and to run that program at the start of each session. Ray. Link to comment Share on other sites More sharing options...
96RAF Posted January 5, 2020 Share Posted January 5, 2020 Ray is correct. In Pro default for points startup is zero, which means they do nothing at startup. As stated you have to manuall yright click each point in Design Mode and allocate a number to each for the order you want them to set in. Link to comment Share on other sites More sharing options...
Exetersteam Posted January 6, 2020 Author Share Posted January 6, 2020 Thanks guys. It works fine now. HRMS also replied. I think it is a case of RTFM for me! 😳 Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 6, 2020 Share Posted January 6, 2020 I've got a program which will set all or some of your points startup sequence numbers to their DCC address if you are interested .... I am a member of the RMWeb Forum with the same username if you want to contact me directly. Ray Link to comment Share on other sites More sharing options...
Exetersteam Posted January 9, 2020 Author Share Posted January 9, 2020 Thanks Ray. I amy well do that but in the meantime I have a few things to sort out with RM. I have just bought a new computer and need to "migrate" RM to it from my laptop and get it working.CheersJohnPS I am JST on RMWeb. Link to comment Share on other sites More sharing options...
