rmt Posted January 27, 2020 Share Posted January 27, 2020 Bought class 90 loco on Ebay, mistake! Loco ran on track for about a minute then stopped, never to run again, any help would be very welcome. Many thanks Link to comment Share on other sites More sharing options...
walkingthedog Posted January 27, 2020 Share Posted January 27, 2020 You had a similar problem 5 years ago with a Class 91. I bit more detail would help us. Link to comment Share on other sites More sharing options...
Going Spare Posted January 27, 2020 Share Posted January 27, 2020 Does the loco have a switch on its roof which changes power collection from the track to the overhead wire? If so, is it set in the correct position for track pick-up?GS Link to comment Share on other sites More sharing options...
96RAF Posted January 27, 2020 Share Posted January 27, 2020 Have a look herehttp://www.halton96th.org.uk/article6.htmlYours may need a tweak or two to improve its pickup capability. As converted mine runs a treat.Standard ringfield motor servicing applies, but you may consider neo magnets or a DVD motor transplant. Link to comment Share on other sites More sharing options...
Tony57 Posted January 27, 2020 Share Posted January 27, 2020 HiThere are thre versions of the Class 90Early ones have a 3 pole Ringfield 1988 -2004The next is a 5 poole ringfield version 2004 - 2008 they were fitted with a DCC socketIt would help if you can give a little more detail on which one you are having problem with either Rnumber or 90xxx. I brought a class 90 only a couple of months ago off ebay and it works great both via track and pantograph.. Link to comment Share on other sites More sharing options...
rmt Posted January 27, 2020 Author Share Posted January 27, 2020 HiThere are thre versions of the Class 90Early ones have a 3 pole Ringfield 1988 -2004The next is a 5 poole ringfield version 2004 - 2008 they were fitted with a DCC socketIt would help if you can give a little more detail on which one you are having problem with either Rnumber or 90xxx. I brought a class 90 only a couple of months ago off ebay and it works great both via track and pantograph..Hi thanks for your response, model number R2048, loco did run with power to track and also using pantograph, will not run either way now! Link to comment Share on other sites More sharing options...
Going Spare Posted January 27, 2020 Share Posted January 27, 2020 Is the locomotive dead on the track or is there a short-circuit within it that is causing the controller to trip out?GS Link to comment Share on other sites More sharing options...
Tony57 Posted January 27, 2020 Share Posted January 27, 2020 First thing I would do would be to drop the motor out of the loco, disconnect the pantograph wire apply power to the motor using the two brush strips to see if the motor works if it works then it is a possible wiring or switch prpblem if it does not then it could be the motor needs a service / overhaul. it is unlikely the commutator has failed , it could just be dirty so needs a good clean and lubrication, it could be the brushes are worn out and need replacing If the motor does work check the switch on the roof is locked into the right position for the track then check the rear bogie wire is connected and it is a good firm connection then have a look at the roof connection to make sure it is good, if you have a tester check the wire is sound, I would test rear bogie to switch, switch to motor, rear bogie to motor, pantograph to motor, ( I have known wire to break inside the plastic cover only testing uncovered the fault).Once everything has been checked and put back together I would put it back on the track and see if it works ok,, I have found on several roof swicthes a slight movement of the switch is require it get the best electrical track. The ringfields of this period are well made do not go wrong very often but still need some care and attention and the wiring is so simple can eaisly be sorted if it goes wromg.I have at least 40 locos from this period and all are still working fine. Link to comment Share on other sites More sharing options...
