Balwyn Posted February 22, 2020 Share Posted February 22, 2020 Hi, I recently purchased an R1177 Duke of Gloucester train set (second hand but immaculate), the engine wobbles badly like a fish on the straight track. The engine see-saws slightly on centre driving wheelsCan anyone advise me what I can do to rectify the problem.This is my first foray into model railway since my childhood, to entertain my grandsons 😉 Link to comment Share on other sites More sharing options...
Chrissaf Posted February 22, 2020 Share Posted February 22, 2020 Most likely the wheels have slipped on the axles such that the coupling rods on each side of the loco are now out of sync. This is called 'quartering'. So use the 'Search Forums' box with the green magnifying glass symbol and search the forum for 'quartering'. Link to comment Share on other sites More sharing options...
Stubaggieboy Posted February 22, 2020 Share Posted February 22, 2020 So does mine! Beautifull looking loco with a poor chassis in my opinion. Link to comment Share on other sites More sharing options...
96RAF Posted February 22, 2020 Share Posted February 22, 2020 Run the loco upside down using a 9v battery on the wheels to see if a wheel is buckled. Check each wheel is tight on the axle and as Chris says Quartered correctly - i.e. one side wheel crank is at 90 degrees to the opposing side. Link to comment Share on other sites More sharing options...
walkingthedog Posted February 22, 2020 Share Posted February 22, 2020 I'm with Chris, its a quartering problem. My loco, until I sold it, ran beautifully. Link to comment Share on other sites More sharing options...
Chrissaf Posted February 22, 2020 Share Posted February 22, 2020 Forgot to add in my initial reply..TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
JJ73 Posted February 23, 2020 Share Posted February 23, 2020 Hiya BalwynWelcome to the Hornby Forum - you have came to the right place 😀 I have the exactly the same R1177 Duke of Gloucester train set as you - I've just checked mine, anothe avanue to check may be, There are 8 small screws along the base of the Loco (See photo) /media/tinymce_upload/1b75a0f8b7e2fb3169a02934f44ce81b.png Are any of these 8 screws either lose or missing??? Link to comment Share on other sites More sharing options...
Going Spare Posted February 23, 2020 Share Posted February 23, 2020 As quartering problems are not the easiest to rectify for a newcomer to the hobby, I am inclined to say return it to the seller as it can not be used satisfactorily without somewhat specialised attention. Link to comment Share on other sites More sharing options...
Balwyn Posted February 24, 2020 Author Share Posted February 24, 2020 Thanks everyone, the quartering was OK I think, but the con-rod connecting the three drive wheels on one side was actually bent vertically and horizontally. So heart in hand I took the rear wheel screw out and gently tweaked it back straight(ish), and success! (must get one of those con-rod spanners though) 😀 Link to comment Share on other sites More sharing options...
Going Spare Posted February 24, 2020 Share Posted February 24, 2020 Thank you for reporting back - many don't!Good to hear it was such an easy fix, Link to comment Share on other sites More sharing options...
LCDR Posted February 24, 2020 Share Posted February 24, 2020 Back to the point M-R wisely makes from time to time, scale appearance is all well and good, BUT it is as naught if it makes the model so flimsy that parts get damaged so easily as to render them useless. Sounds like the new 'Rocket' is likely to be a victim. ☹️ Link to comment Share on other sites More sharing options...
Modelnut19 Posted February 26, 2020 Share Posted February 26, 2020 My own Duke of Gloucester does waddle a bit but not too badly. This does suggest that there was a quality problem with some of them. I do hope that you get it sorted or at least improved. However, taking a chassis apart is not for the faint hearted. Make sure you have the correct tools to undo the coupling rods to try to improve the quartering.Having said all that, I have examined mine and the quartering seems to change significantly as it is run and yet it still runs okay (at the moment)! Bizarre! Link to comment Share on other sites More sharing options...
Going Spare Posted February 26, 2020 Share Posted February 26, 2020 Have a look at the poster's report of a successful outcome on Monday! Link to comment Share on other sites More sharing options...
walkingthedog Posted February 26, 2020 Share Posted February 26, 2020 Modelnut the quartering can't change as it runs. It is either wrong or correct. Glad the OP solved his problem. Link to comment Share on other sites More sharing options...
Balwyn Posted March 4, 2020 Author Share Posted March 4, 2020 Disaster! 🫨The front Coupling Rod screw came loose and fouled slide block and slide, snapping off the slide, the piston rod is still connected to the connecting rod and the Loco still runs. Unfortunately this locomotive is now obsolete in the Hornby range and the spare parts all but non existant.Does anybody know if another locos valve gear is compatible Link to comment Share on other sites More sharing options...
walkingthedog Posted March 4, 2020 Share Posted March 4, 2020 Lots of spares on Peters Spares, have you looked. Here's an example. https://www.petersspares.com/hornby-x6599-class-8-duke-of-gloucester-cylinder-block.ir Link to comment Share on other sites More sharing options...
atom3624 Posted March 4, 2020 Share Posted March 4, 2020 Is the slider broken, or simply pulled out of the block?As WtD mentions, all manner of spares available from time to time - Peters and Ebay.Often spare chassis come up - not cheap, but a simple 'fix'. Al. Link to comment Share on other sites More sharing options...
