96RAF Posted February 22, 2020 Share Posted February 22, 2020 I have moved the layouts of my Virtual Railway from Windows 7 to Windows 10 with the relevant patches. I have built 2 lay outs. 1 :- called Dinky land. 2:- called Horby 5. I can open Dinky land and it works fine but when I try to open Horby 5 the system closes down. Both Dinky land and all the preset layouts work but not Hornby 5. Both layouts worked on Windows 7 and where saved after alterations to the track etc. Link to comment Share on other sites More sharing options...
Bexhill Donkey Posted February 23, 2020 Share Posted February 23, 2020 You may try: right-click on the icon and check 'run as administrator'. If that doesn't help, try changing the screen resolution. If that doesn't solve it either, try setting 'XP compatible' or a combination of these options. Link to comment Share on other sites More sharing options...
