Specially Constructed Railway Wagons
Guest Chrissaf
Part 2
Great Western Railway  used the following telegraph codes –
POLLEN – Girder wagon
TOTEM – Armour Plate
SERPENT – Roll Wagon, Car Truck
CROCODILE – Well Trolley, Flat Trolley, Boiler Trolley, Transformer
RECTANK – Rectank
MOREL – Propellor Trolley
LORIOT – Lowmac, 4 wheel Flat Trolley
BEAVER – Flat Truck
GADFLY – Flat Truck
HYDRA – Lowmac
MAYFLY – Four wheel transformer truck
Part 3
London and North Eastern Railway   used telegraph  codes as follows –
Armour Plate Wagon – ARM
Bell wagon – BELL well wagon for carrying church bells etc.
Boiler – BOILER
Flat wagon – FLAT
Glass wagon – GLASS / WELL GLASS
Gunset – GUNSET
Machine wagon, high ramped – IMP (same as BR HYMAC)
Machine wagon, low ramped – MAC (Same as BR Lowmac)
Twin machine wagon, ramped – TWIN IMP
Rectank ramped – RECTANK
Traction engine – TRACTION
Pulley or Wheel wagon – PULLEY
Transformer – TRANSFORMER
Flat trolley wagon – FLATROL
Open Well wagon (removable crossbars) – WELTROL
Propeller trolley wagon – PROTROL
Trestle trolley wagon – TRESTROL
Part 4
London Midland and Scottish Railway used letter telegraph codes –
Armour Plate – HAX, AZ, AE
Gunset – GUNSET MB, GUNSET M
Low Machine – U10, U1R
Low Machine, Chemical Pan - U10
High Machine – TRK
Deep Case Truck – DCK
Glass Truck – GLK
4 wheel Flat Trolley – TYK, TYO, TYR
Bogie Flat Trolley – BTO, BTZ
Bogie Trestle Trolley – BTA, BTZ, BTP, BTE
Bogie Well Trolley – BTZ, BTP, BTC, BTO
Transformer – BTY, BTW
Girder Set – TGP, TGT,
Will do WTD,
AM Yes a lot of these wagons have entered presevation, and a look at the Vintage Carriage Trust Wagon Register can be quite an eye opener. Unfortunately the Website where the register is stored is faulty at present.
/media/tinymce_upload/06905c19e94e3fe308bdf6d198e40ef7.JPG
This is the Boiler Set (BOILER EB) at Locomotion Shildon in 2005.
Many are still in use, this is a Weltrol WP at Pickering NYMR
/media/tinymce_upload/7757b5875b3d91bea9028c4e7e57db49.JPG
A few more images
Flatrol EV at York
/media/tinymce_upload/c5c659ef27d5a6294e6cc8012b31e97a.jpg
Flatrol MVV
/media/tinymce_upload/5f99bc54c33d641be4c27fb967c226f7.jpg
Bogie of Weltrol EC
/media/tinymce_upload/983fe7fb459436fd42953edb0b072d1a.jpg
Flat ET
/media/tinymce_upload/c2897e8038ff1272445defd16a19dbed.jpg
Flatrol MJ (Nuclear Flask)
/media/tinymce_upload/4d0eb0c6c08800ccc626f6aabca44eba.jpg
Trestrol EO
/media/tinymce_upload/1904685244e54aa854b3e66234f5059e.jpg
  • 3 weeks later...
No, however they did make the Lowmac MS/SG/EU (various numbers including R6075) which was an old Airfix model (54330).
Triang used to make a freelance version of the Crocodile / Weltrol (R118) , and a overly short version of the Trestrol EC (R242) , both of which got turned into various Battlespace wagons. Using some broken Battlespace vehicles a lot of plastic cement and lots of plastic microstrip, I converted the short Trestrol EC s into a scale length Trestrol EC.
Mainline made a GW Crocodile H / BR Weltrol WH, which found its way into the Bachmann range.  Bachmann also make the FNA nuclear flask transporter, and the bogie Warflat tank transporter. Oxford Rail / Hattons make the bogie Warwell
Arising from another thread I have compiled the following guide to Special Constructed Railway Wagons which were built to carry exceptional loads.  The name of the type is followed by the code name in capital letters, and a brief description. I hope this may prove useful.
Part 1. British Railways telegraph codes for Specially Constructed Wagons –
Armour Plate – ARM – Short bogie flat wagon for heavy concentrated loads  (British Railways standard type codes ARM WE, WF, EL, ET)
Boiler – BOILER – Bogie wagon for carrying boilers, originally intended to carry Lancashire boilers in a cradle in the wagon deck.  (BOILER EG, EF), Also a multi axle wagon for carrying power station steam boilers  (BOILER EB).
Chemical Pan – LOWMAC MH – Four wheel depressed centre wagon for carrying chemical pans, a Lowmac with a hole in centre of deck, and timber baulks.
Flat – FLAT – Long bogie flat wagon for awkward loads, also 4 wheeled flat wagon. (FLAT  ED, EL, EQ, ET, EU, WG)
Girder – GIRDER – Separate bogie frames with turn tables for carrying exceptionally long loads such as bridge girders. The load becomes part of the wagon unit. (GIRDER WG)
Glass – GLASS – 4 wheel and bogie well wagon with supporting frame for glass in crates. (GLASS WC, EO, EP)
Gun – GUNSET – multiple bogie wagon for carrying large naval gun barrels.
Machine – LOWMAC – four wheel wagon with ramped ends and deck below 3’ above rail for wheeled machinery suitable for loading from end dock . (LOWMAC AB, EK, EO, EP, ER, ES, ET, EU, MR, MS, MU,SC, SF, SG, SH, WBB, WE, WP, WN, WV)
Machine – HYMAC - four wheel wagon with ramped ends and deck 3’ or over above rail for wheeled machinery suitable for loading from end dock . (HYMAC EP, EX)
Rectank – RECTANK – bogie wagon with ramped ends for wheeled /tracked machinery for loading from end dock. (RECTANK EC, WC)
Carriage truck – CARTRUCK -   unfitted, CARFIT - with vacuum brake, – four wheeled flat wagon for wheeled vehicles for loading from end dock.
Roll- ROLL – four wheeled wagon for steel mill rolls in cradles.
Stator – STATOR – multi axle wagon for carrying generator Stators suspended on long girders between bogies
Transformer – TRANSFORMER – bogie wagon with removable side girders between bogies for carrying large transformers and similar indivisible loads slung between them. (TRANSFORMER MC)
Trestle plate – TRESTLE –  four wheel or bogie wagon for carrying wide plates on angled trestles. (TRESTLE AA, AB, EA, ED, EH)
Trolley, flat – FLATROL – four wheel or bogie wagon with depressed level flat deck between raised ends.  Removable longitudinal baulks.(FLATROL EA, EAB, EAC, ED, EDC, EG, EL, EN, ET, EV, EX, EY, EZ, MCC, MDD, MHH, MJ, MSS, MUU, MVV, SB, WW, WX
Trolley, propeller – PROTROL- . four wheel or bogie wagon with depressed well between raised ends with opening for carrying ships propellers supported between longitudinal timber baulks.(PROTROL ED, EG)
Trolley, trestle – TRESTROL – four wheel or bogie wagon with depressed well for carrying extra wide plates on angled trestles.(TRESTROL AB, EC, EO, EJ, EN, MO)
Trolley, well – WELTROL – four wheel or bogie wagons with depressed well deck between raised ends. Removable longitudinal baulks.(WELTROL EB, EC, EJC, EL, ENN, EP, MA, MC, MV, WBB,WGG, WH,  WJ, WL, WP, WW, WZ)
Wheel – WHEEL – four wheel or bogie wagon with framework to support colliery winding head gear wheels carried vertically. (WHEEL EA, EL)
WD Flat (for tanks) – WARFLAT – 50 ton flat wagon originally intended for armoured fighting vehicles.
WD Case (for crates) – PARROT – 50 ton wagon originally intended for crates of aircraft parts
WD Well (for tanks) – WARWELL –50 ton well wagon originally intended for armoured fighting vehicles.
(WD = War Department)
Specially Constructed wagons used by the Civil Engineer
Four wheel  flat trolley – LORIOT
Multi Axle Boiler wagon modified to carry bridge girders – BRIDGE
150 ton Girder wagon set - CONGER
