rob144 Posted March 29, 2020 Share Posted March 29, 2020 Is there a way to fit nem couplings to a non nem pocket coach have brought some of the new hunt couplings but my coaches are all the old tension lock couplings any help please Link to comment Share on other sites More sharing options...
walkingthedog Posted March 29, 2020 Share Posted March 29, 2020 You can buy NEM pockets from DCC Supplies that can be fitted with a screw. Will need a bit of mini engineering but that is what railway modelling is all about.https://www.dccsupplies.com/search/results/?search=Nem+pockets Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted March 29, 2020 Share Posted March 29, 2020 Also, Parkside, now part of PECO, make a plastic mounting block, to take a NEM pocket, that can be glued in place, once you have prepared a mounting place. Don't forget that the NEM pocket should be mounted at the correct height. There are also other systems for attaching NEM pockets Symons being one... Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted March 29, 2020 Share Posted March 29, 2020 That should be Symoba. http://www.dccsupplies.com/item-p-103641/symoba-120-coupling-conversion-start-set eBay NEM adaptors. http://www.ebay.co.uk/itm/202794963730 The Parkside mounting blocks.(Example only, to shew the item) http://www.ebay.co.uk/itm/323454984528 Link to comment Share on other sites More sharing options...
ellocoloco Posted March 30, 2020 Share Posted March 30, 2020 @rob144 The problem you have is not just the lack of NEM pockets, its the lack of close coupling mechanisms on the coaches you mention above. Hunt couplings are a 'solid' coupling unlike tension lock types and require suitable movement in the NEM pocket to negotiate curves and an extending bar to utilise the advantages of the Hunt system. As such the NEM options suggested by WTD and Sarah above are not really suitable. You could try Roco 40343 or Roco 40344 which are designed for slightly shorter coaches than you have, but as WTD says 'Will need a bit of mini engineering but that is what railway modelling is all about.' These may seem expensive but each pack contains enough for six coaches. Correct height is important and as these are designed for HO they will need 'packed' under higher OO models. In a recent similar themed post, Chrissaf provided a fascinating link to a site all about couplings and Keen systems also offer a close coupling retrofit option though this doesn't include NEM pockets. Best of luck and let us know how you get on............... Link to comment Share on other sites More sharing options...
walkingthedog Posted March 30, 2020 Share Posted March 30, 2020 Sarah I had slready sent him a link to DCC Supplies. Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted March 30, 2020 Share Posted March 30, 2020 @WTD. Yes, but my link below was to a different part of the DCC supplies site...Symoba system... 😉 @ellocoloco The Keen System parts I have seen do have an open bottom mount, very close to the NEM pocket size...they do a dummy buckeye coupling to fit. The coupling mating with another by being attached vertically... NEM couplings do fit, but can drop out. Either a base could be glued on, or the coupling glued in place, though that negates one reason for havin NEM pockets. I think that the Symoba system does include some close coupling sliding mountings as well... http://www.petersspares.com/103642-dcc-supplies-symoba-111-nem-conversion-sliders-kinematic-coupling.ir 103642 DCC Supplies Symoba 111 NEM Conversion Sliders (kinematic coupling) The 'slider' (A.K.A. short coupling mechanism) is used to replace the existing coupling mount (it can also be chassis mounted).This then acts as a spring loaded centring mechanism for your coupler, ensuring that it is always central.An appropriate NEM pocket is chosen suitable for the model and is fitted onto the square pin.Once the correct height is set (using a height gauge/rule), the pin is cut to length. Packaging: 1 pair (2 pieces).Base Dimensions: 12mm x 11mm x 2mm[/Quote] Link to comment Share on other sites More sharing options...
walkingthedog Posted March 31, 2020 Share Posted March 31, 2020 @WTD. Yes, but my link below was to a different part of the DCC supplies site...Symoba system... 😉 So was mine did you look. Never mind I'll get over it 😆 Link to comment Share on other sites More sharing options...
atom3624 Posted March 31, 2020 Share Posted March 31, 2020 Time for a change of Avatar ..... 😀 Nothing against Labradors - very nice dogs .. Link to comment Share on other sites More sharing options...
walkingthedog Posted March 31, 2020 Share Posted March 31, 2020 I'm phasing myself off this forum atom. Could be my last day. Link to comment Share on other sites More sharing options...
