Chrissaf Posted June 2, 2020 Share Posted June 2, 2020 Do you have any points? If so, is this where the issues arise? Out of gauge metal wheels where the Back to Back distance is incorrect or metal wheels being too wide and bridging the points frog rails can lead to shorts and abrupt stopping. Unless the wagons are pressing down in the rear of the loco and in turn lifting one set of the loco wheels off the rails slightly due to incompatible couplings? Another thing worth checking is that no wagon wheels are seized and all rotate freely as seized wheel(s) will add drag to the loco and in turn could cause the locos motor to draw too much current and trip out? Otherwise, I've not heard of any issues a wagon can cause. Link to comment Share on other sites More sharing options...
Chrissaf Posted June 2, 2020 Share Posted June 2, 2020 I recently started from scratch and bought a Hornby Terrier with DCC and 3 random goods wagons, The Loco will run for hours on its own without any problem at all.As soon as I attach the wagons, it starts to stall and run erratically with no obvious pattern Trial and error shows the problem to be with two Dalpol wagons, if I leave them out everything runs just fine.Any ideas? Link to comment Share on other sites More sharing options...
roger v Posted June 2, 2020 Share Posted June 2, 2020 Thanks, 😀I am confident it is neither the wheels nor the points, the fault occurs on straight track,However I thought the couplings were acting a bit strange from the start, the Dalpol ones hung lower and I got random un-couplings for no obvious reason. How could they be incompatible? Link to comment Share on other sites More sharing options...
Flashbang Posted June 2, 2020 Share Posted June 2, 2020 Hmm.... Dapol and Hornby are completely different. One may not match the other exactly!What needs to be determined is why these wagons cause the running issues? Have you checked the wagon(s) wheels for free running? Link to comment Share on other sites More sharing options...
Scumcat 01 Posted June 4, 2020 Share Posted June 4, 2020 Dapol wagons wheels and couplings are rubbish, the back to backs are always wrong the flanges are deep and the couplings droop sometimes they catch on the track. I had a problem with derailing It was a problem with the couplings. Poor quality, I replaced them and the wheels and they are now fine. I usually won't buy dapol wagons that's why they sell cheap. Link to comment Share on other sites More sharing options...
john_doman Posted June 5, 2020 Share Posted June 5, 2020 I think Dapol wagons are very good, especially the weathered ones. Drooping couplers can be an issue, replaced all mine with kadees, they go well. I do weight all my wagons with 25 grams of tyre weights, they run better as a result. Link to comment Share on other sites More sharing options...
Scumcat 01 Posted June 5, 2020 Share Posted June 5, 2020 I think Dapol wagons are very good, especially the weathered ones. Drooping couplers can be an issue, replaced all mine with kadees, they go well. I do weight all my wagons with 25 grams of tyre weights, they run better as a result.The actual wagons aren't bad, I said the wheels and couplings are rubbish these parts are unusable. Link to comment Share on other sites More sharing options...
96RAF Posted June 6, 2020 Share Posted June 6, 2020 I used to have a coach and wagon tester track. It was a long plank of wood with a slalom of spare straight and curved track and points mounted to it. The plank could be tipped up at one end and rolling stock allowed to run free singly and in rakes to see if there were any problems. On the flat rakes could be pulled and pushed by a loco to look for problems. Long since gone unfortunately as layouts have evolved. Link to comment Share on other sites More sharing options...
