BlightyExPat Posted June 3, 2020 Share Posted June 3, 2020 I have a couple of Loksound decoders that have worked without any issues using my Hornby Elite DCC controller.Whilst attempting to use with a newly built MERG hardware and Raspberry Pi/JMRI controller one of these decoders no longer has no motor control. As soon as I apply the smallest of speed the loco runs at what appears to be maximum speed, regardless of whether I use the MERG/Raspberry Pi/JMRI or the Hornby Elite.The decoder will accept a new address and all sounds are as they were originally programmed, I only have a speed control issue.Could you please advise what the problem might be and how I might be able to rectify it? Link to comment Share on other sites More sharing options...
Howbi Posted June 3, 2020 Share Posted June 3, 2020 It may be that DC running is enabled which causes runaway..........read CV29 then deduct 4 and write the result back to CV29........see CV29 calculator here... http://www.2mm.org.uk/articles/cv29%20calculator.htm ..........HB Link to comment Share on other sites More sharing options...
jane1707819582 Posted June 3, 2020 Share Posted June 3, 2020 Your decoder could beinerpratati gthe signal as DC .disable DC running in cv 29 find the value and take 4 off Link to comment Share on other sites More sharing options...
Chrissaf Posted June 3, 2020 Share Posted June 3, 2020 If CV29 makes no difference..Using the Elite. Write 8 to CV8 to reset the Loksound to factory default. You have no way of knowing what CVs may have been altered by the Merg/PI controller. A factory reset should theoretically restore factory motor control and, of course, DCC Address 03. If 8 to CV8 rectifies the issue, then I would suspect the MERG/PI controller as the cause of it. Link to comment Share on other sites More sharing options...
BlightyExPat Posted June 4, 2020 Author Share Posted June 4, 2020 Good news. I struggled to fix via the CV29 route, so did a factory reset CV8 to 8 and all appears to be OK, now..Thanks to all for their help. Link to comment Share on other sites More sharing options...
