Barry1969 Posted July 9, 2020 Share Posted July 9, 2020 Hi does it matter if you fit decoder the wrong way around on Steam loco. I know it will run backwards but does it matter. The 1 hole is not clearly marked on the 61xx and don't really want to take body off again to change. Link to comment Share on other sites More sharing options...
Howbi Posted July 9, 2020 Share Posted July 9, 2020 It is easily resolved by changing CV29 basically by adding 1 to the existing value..........that is of course if your controller is capable of reading/writing CVs........CV29 calculator here ............HB Link to comment Share on other sites More sharing options...
Barry1969 Posted July 9, 2020 Author Share Posted July 9, 2020 It is easily resolved by changing CV29 basically by adding 1 to the existing value..........that is of course if your controller is capable of reading/writing CVs........CV29 calculator here ............HBThank you so much Link to comment Share on other sites More sharing options...
96RAF Posted July 10, 2020 Share Posted July 10, 2020 The correct alignment is only important if you have lighting which most steamers do not. If lighting is fitted and the plug is reversed the lights simply do not work, a definite clue that the plug is in the wrong way round. If you look at the inner four connections on a NEM652 socket you will see why this is and if you look at the outer four connections you will understand why the loco runs backwards to normal. Link to comment Share on other sites More sharing options...
