Canford West Posted August 6, 2020 Share Posted August 6, 2020 Hi all I hope someone can help me I've just purchased a new Select and 2 new Farrish Prairies with the chips, they worked great in the shop but will not run when I got them home and went to runthem with my Select. I have followed the instructions to reset them up (in the shop they use Gauge Master) but all I keep getting is the redlight bleeping 8 times not 7 like the manual says should happen. Can anyone help me get them running?ThanksMal Link to comment Share on other sites More sharing options...
96RAF Posted August 6, 2020 Share Posted August 6, 2020 As your Select is new we can assume the latest revision state - the number 20 or 16 will show at start up then 30 then 03 tellin us it is ready for use with address 3. If not take it back to the shop you bought it from and get them to send it to Hornby for an update at their cost. Did the shop give the locos new address numbers and if so were they within the range 1 to 59 as this is the Select loco address range. Often when a loco is addressed by one controller it may not be recognised by another controller. If so just readdress it on the Select by long pressing Select, see LA on screen, input your chosen address between 1 and 59 avoiding 3 which is the default factory address a new decoder has. Press Select again and try it. If this fails reset the decoder by writing value 8 to CV8 (most decoders use this but check your paperwork), then see if it responds to address 3 before giving it a new address as above. If none of that works come back telling exactly what key strokes you have done with what result. Link to comment Share on other sites More sharing options...
Mac-_- Posted August 6, 2020 Share Posted August 6, 2020 If your reprograming your trains on the main track, remember too only have the train your programing on the track. Better too have a spare piece of track for programing. Link to comment Share on other sites More sharing options...
Canford West Posted August 7, 2020 Author Share Posted August 7, 2020 Thanks for the information, I am using a spare piece of track as the instructions say only use one loco at a time. I will follow your instructions and let you know how I get on 😆 Thanks againMal Link to comment Share on other sites More sharing options...
