pixvalley Posted August 12, 2020 Share Posted August 12, 2020 When I programmed my Class 66 TTS chip testing it in an ESU rig at default address 3. My TTS Mallard creeps away and will not respond to the handset.Gaugemaster prodigy advance 2 Loco manufacturer HornbyChip manufacturer Hornby TTS Locomotive MallardCV 1 Loco 4468 CV 2 Start Voltage 0 CV 3 Acc Momentum 15 CV 4 Dec Momentum 15 CV 5 Top Voltage 0 CV 6 M Voltage 0 CV 7 Decoder Version 14 CV 8 Manufacturer 48 CV 17 209 CV 18 116 CV29 addressing 34 CV29 reverse direction no Link to comment Share on other sites More sharing options...
STG Posted August 12, 2020 Share Posted August 12, 2020 Presumably, you used the test rig in programming track mode, and with the rest of the layout disconnected, or used it as programming on the main.Else, you might find the two locos have been programmed onto the same address.If possible, try a factory reset of the decoders at fault. Link to comment Share on other sites More sharing options...
96RAF Posted August 12, 2020 Share Posted August 12, 2020 Possible casue is due to DC running being ensbled which it is not on your Mallard.Can you check you do not have the PA2 set for loco zero. Is so disable it. Link to comment Share on other sites More sharing options...
