Chrise Posted October 13, 2020 Share Posted October 13, 2020 I want to install a sound decoder into my DCC ready class 67 but even though there is an 8 pin socket I cannot work out where to put the speaker and decoder.the particular loco was a set with 3x EWS ballast wagons which is a fabulous loco with running lights and very heavy.can anyone help please Link to comment Share on other sites More sharing options...
96RAF Posted October 13, 2020 Share Posted October 13, 2020 Have a look at HSS383 bottom left hand corner. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 13, 2020 Share Posted October 13, 2020 Extract below from HSS 383 showing the speaker position that Rob is referring to.../media/tinymce_upload/ae6b98b1bf9c3da5c4c0f682704d55b0.jpg Link to comment Share on other sites More sharing options...
Chrise Posted October 13, 2020 Author Share Posted October 13, 2020 Brilliant thanks looks like I've got to do a bit of unscrewing to fit this Link to comment Share on other sites More sharing options...
96RAF Posted October 13, 2020 Share Posted October 13, 2020 You will probably find you need to unsolder the speaker from its wires then extend the decoder wires in order to feed them down through the chassis frame and resolder to the speaker. Be carefull approaching a speaker with a soldering iron as the magnet will grab the iron tip. Link to comment Share on other sites More sharing options...
