jane1707819582 Posted October 26, 2020 Share Posted October 26, 2020 As long as it fits OK then yes . Link to comment Share on other sites More sharing options...
RB51 Posted October 26, 2020 Author Share Posted October 26, 2020 hi all can I run a hornby TTS sound decoder for a class 37 deisel loco in a Class 27 deisel loco as hornby do not appear to manufacture a chip for this loco , will the sounds work ok thanks Andy Link to comment Share on other sites More sharing options...
96RAF Posted October 26, 2020 Share Posted October 26, 2020 The answer to all your questions is Yes, but are the Cl 37 sounds suitable for a Cl 27 maybe should have been the question. You should listen to UTube videos of each class and compare motor noise, horns, ancilliaries, etc. Class 37 had a refurb and the starter sounds are different between those variants and the TTS version is pre-refurb I believe (I can only be 180 degrees out on this). Link to comment Share on other sites More sharing options...
Sultan Posted October 26, 2020 Share Posted October 26, 2020 In short Class 37 and class 27 power units are by different manufactures, ie English Electric and Sulzer and sound very different. As RAF96 suggests do some research onYouTube to ensure that you will be satisfied. Link to comment Share on other sites More sharing options...
