Mar Mallard Posted November 3, 2020 Share Posted November 3, 2020 Hi, I have bought a lovely West Country Class but cab ladder snapped and broken piece got lost. Where on earth could I find a replacement and would removing old ladder cause more damage? Thanks, Chris Link to comment Share on other sites More sharing options...
threelink Posted November 3, 2020 Share Posted November 3, 2020 I had a similar problem on a BR1b tender and dug out from the spares box an old Airfix kit tender on which the steps were an exact match, so sliced off a step and substituted it for the broken step using superglue. If you have an old Airfix BoB lying about you may be able to do the same. Alternatively you may be able to find a brass signal ladder of the right dimensions to provide a match. Good luck with the repair! Link to comment Share on other sites More sharing options...
Derek 19B Posted November 3, 2020 Share Posted November 3, 2020 Hi RT models have all you require , rtmodels.co.uk Derek 19b 😎 Link to comment Share on other sites More sharing options...
Lyd 85B Posted November 3, 2020 Share Posted November 3, 2020 I've fabricated similar items using sprue and unused parts from plastic kits, but my best results have come from styrene section, such as Evergreen or Plastruct, using a solvent like Plastic Weld. Once spray-painted they are a very close match to the original. Link to comment Share on other sites More sharing options...
