Landyern Posted December 2, 2020 Share Posted December 2, 2020 This is probably in here somewhere but I can't find it Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 2, 2020 Share Posted December 2, 2020 It is, multiple times and recently. Start by changing CV150 from default zero to 1 (Write 1 to it). Link to comment Share on other sites More sharing options...
96RAF Posted December 2, 2020 Share Posted December 2, 2020 Here one with almost exactly the same title - found by searching on ‘jerky’ alone https://www.hornby.com/uk-en/forum/flying-scotsman-tts-sound-jerky-start/ Link to comment Share on other sites More sharing options...
Chrissaf Posted December 2, 2020 Share Posted December 2, 2020 .....but I can't find it. For the future.... the Hornby forum search function is dire, but does work best if you search for single words and not phrases. The search engine is incapable of finding near hits, only 100% exact matches. The secret is to think of a suitable single word that the thread you are looking for might contain which is not always easy. Read TIP10 in my TIPs page which describes how to use Google's Advanced Search Engine to search only the Hornby forum and no other Internet site. I use this documented technique a lot to locate those long distant forum posts lost in time. https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/ However, in this case use "jerky" as the single word search term without the " " marks in the "Search Forum" box and you get about 10 hits where the word "jerky" appears in the topic title, some of which also have TTS in the title as well [see screen capture below], using the 'search post contents' option returns over 250 hits. /media/tinymce_upload/3880a4aeb4e453f1bad79390d91a25f6.jpg As Fishy says, changing CV150 usually fixes this issue. But you do need a controller capable of changing CVs to do it. EDIT: Rob just beat me to the post. His posted link is the second one up from the bottom in the topic title search results. Link to comment Share on other sites More sharing options...
Landyern Posted December 3, 2020 Author Share Posted December 3, 2020 Thanks for the replies, however changing cv150 to 1 is far better but it still seems to strain as if not getting enough electricity and the jerking forward every so often and is the same in reverse. Thanks Link to comment Share on other sites More sharing options...
96RAF Posted December 3, 2020 Share Posted December 3, 2020 You now need to fiddle with CVs 153/4 which refine the motor algorithm.If you had left CV 150 set at value zero then you would fiddle with CVs 151/2.There is another thread on here which explains to some extent the ‘science’ and methodolgoy behind these further P&I adjustments.Probably one of those in that search list. Link to comment Share on other sites More sharing options...
Mac-_- Posted December 4, 2020 Share Posted December 4, 2020 I asumme every thing is clean. Link to comment Share on other sites More sharing options...
Landyern Posted December 5, 2020 Author Share Posted December 5, 2020 Hi, yes everything is nicely clean, I have it working smooth and crawling smooth however it's strange because when I first switch on it is jerky again but after say a loop or maybe two everything settles down and she's smooth again. Thanks for all the help Link to comment Share on other sites More sharing options...
creilly81 Posted December 7, 2020 Share Posted December 7, 2020 Not wishing to say the obvious, but have you checked the valve/motion gear to see if there is anything bent or catching? Link to comment Share on other sites More sharing options...
96RAF Posted December 7, 2020 Share Posted December 7, 2020 If it works fine after warming up then maybe the loco needs a clean and lube. Some motors do run better when warm, which is why RM suggests running a loco for a few laps before calibrating its speed. A bit like an old car really, not running smoothly until you got the choke fully in a couple of miles down the road. Link to comment Share on other sites More sharing options...
Mac-_- Posted December 7, 2020 Share Posted December 7, 2020 Sounds abit like my self in the mornings Redesdale :(. Out of curiosity where abouts do you have the layout. I know some of my old loco's don't like being first on the track in the uninsultated roof space, this time of year. Link to comment Share on other sites More sharing options...
