HST43 Posted December 18, 2020 Share Posted December 18, 2020 Hi there.I'm looking to upgrade the PSU to the 4amp, but I have a spare switchmode 15V 5amp PSU from an old laptop would this be suitable to use for the elink ?thanks Link to comment Share on other sites More sharing options...
Chrissaf Posted December 18, 2020 Share Posted December 18, 2020 Some, nay many, on here will say yes. But there is at least one thread on here where a member's eLink was damaged and needed repair after using a non Hornby ex Laptop 5 Amp supply. Now it may be that, that user was unlucky and had an eLink with an underlying fault. But do you really want to take the risk. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 18, 2020 Share Posted December 18, 2020 If you do want to take the risk, you need to make sure the plug is compatible for a start, Chris can advise the spec for that I'm sure. Link to comment Share on other sites More sharing options...
Chrissaf Posted December 19, 2020 Share Posted December 19, 2020 6.3mm outer diameter 3.0mm diameter inner [positive] pin. However 6.3mm with 3.0mm inner pins are more difficult to source. The 6.3mm / 3.1mm plug is more common and totally compatible with the Hornby power socket. Link to comment Share on other sites More sharing options...
HST43 Posted December 20, 2020 Author Share Posted December 20, 2020 Hi Chris ,I've found this one online at a very reasonable priceToshibia laptop power supply same spec as the Hornby one.Product Specification Connector size: 6.3*3.0mm Product Type: AC adapter/Battery charger AC Input: 100~240V / 50-60HZ Output: 15V 4A Watts: 60W Link to comment Share on other sites More sharing options...
Chrissaf Posted December 20, 2020 Share Posted December 20, 2020 Its totally up to you. I am not prepared to make a recommendation about a non Hornby power supply. Link to comment Share on other sites More sharing options...
Rog RJ Posted December 20, 2020 Share Posted December 20, 2020 Make sure the plug polarity is the same as the Hornby one. Link to comment Share on other sites More sharing options...
96RAF Posted December 20, 2020 Share Posted December 20, 2020 Various online blurbs about the Hornby power supply describe it as swtiched mode.It is also identical to the Scalextric C7024 unit. Link to comment Share on other sites More sharing options...
