Chrissaf Posted December 29, 2020 Share Posted December 29, 2020 I was running two locos id 003 and id 006 on same layout the id 006(non sound) was causing id 003 (sound) to run intermittently. Whe the non sound one was stopped other ran fine. Any suggestions Link to comment Share on other sites More sharing options...
96RAF Posted December 29, 2020 Share Posted December 29, 2020 Which decoders are in each loco and what controller are you using. How big is the track and how is it powered, etc. Are there any accessory decoders running from the track.Cross talk is not unknown and can be pinned down to degradation of the DCC signal by whatever means - e.g. poor bus system, no bus system, wrong track power connector, lack of snubbers, simply dirty track and/or wheels, two locos passing close by each other, etc. Link to comment Share on other sites More sharing options...
Howbi Posted December 29, 2020 Share Posted December 29, 2020 Probably a case of lack of power from the 1 Amp PSU that comes with Elink and maybe time to upgrade to the 4 Amp power supply...........HB Link to comment Share on other sites More sharing options...
