cruiser Posted May 21, 2012 Share Posted May 21, 2012 hi a have the elite but have not done any thing to do with cv's yet as i dont know what i am doing i did manage to read the cv's on one train but it was all new to me so did nothing.anyway my question is i have A1A-A1A br subsector CLASS 31 DIESEL WITH SOUND but when started it pulls away very fast and when stopped it stops right away what cv's do you adjust and how do you do it could someone please show me if its possible or point me to a video of how to do it..many thanks looking for a gradual pull away and gradual stopcruiser Link to comment Share on other sites More sharing options...
cruiser Posted May 21, 2012 Author Share Posted May 21, 2012 is any of above possible in railmaster as i have that Link to comment Share on other sites More sharing options...
stevecamden Posted May 21, 2012 Share Posted May 21, 2012 Sounds like you need to adjust the accel/decel values from the Elite with the loco on the programming track - its in the Elite manual and very simple - just play around with a few numbers till you get what you want for your layout. Link to comment Share on other sites More sharing options...
poliss Posted May 21, 2012 Share Posted May 21, 2012 Should be even simpler with Railmaster. Link to comment Share on other sites More sharing options...
cruiser Posted May 21, 2012 Author Share Posted May 21, 2012 many thanks for your replies Link to comment Share on other sites More sharing options...
Graskie Posted May 21, 2012 Share Posted May 21, 2012 Things are never that easy, cruiser. Come back to the forum if you have no success with the advice given. Members are very keen to help. Link to comment Share on other sites More sharing options...
hosh Posted May 22, 2012 Share Posted May 22, 2012 http://www.dccwiki.com/Configuration_variable Link to comment Share on other sites More sharing options...
poliss Posted May 22, 2012 Share Posted May 22, 2012 In Railmaster check the section 'Defining and Controlling Locomotives. You should find your Class 31 is already listed. The default cruising and shunting speeds have been pre-defined. Link to comment Share on other sites More sharing options...
96RAF Posted May 22, 2012 Share Posted May 22, 2012 ...is already listed. The default cruising and shunting speeds have been pre-defined...The Q is not the speeds but the accel/decel transitions which can be adjusted by trial and error (set values from 0 to 255) to suit in the Elite menus.Railmaster may also be able to set these values but I am not familiar enough to so advise.Rob Link to comment Share on other sites More sharing options...
poliss Posted May 22, 2012 Share Posted May 22, 2012 There were other things in the Railmaster manual about adjusting speed and acceleration/deceleartion that I haven't fully brushed up on. With a good computer program you won't ever need to refer to CVs.Railmaster Manual.https://www.hornby.com/downloads/hornby-railmaster-instruction-manuals/ Link to comment Share on other sites More sharing options...
cruiser Posted May 24, 2012 Author Share Posted May 24, 2012 hi guys sorry but i have not been able to try anything yet with the train as its been far too warm in the shed to be comfortable doing anything hitting 38c will post how i get on as soon as i get a chance Link to comment Share on other sites More sharing options...
Graskie Posted May 24, 2012 Share Posted May 24, 2012 Try doing it during the Jubilee celebrations. It's bound to be cool and wet then, just likethe Coronation in 1953. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 25, 2012 Share Posted May 25, 2012 Cruiser, when you get out there, this change is a simple one done via the menus, so no cv knowledge needed. Look at your manual and you should see it including what the default values are. And if I remember rightly, this one can be programmed on the layout, no program track needed. Link to comment Share on other sites More sharing options...
poliss Posted May 25, 2012 Share Posted May 25, 2012 I'd suggest you get some insulation in the shed or you could get warped track from the expansion and contraction of the badeboard. Link to comment Share on other sites More sharing options...
cruiser Posted May 28, 2012 Author Share Posted May 28, 2012 shed sides are all inulated poliss loft insulation and gyprock fitted only roof that's not. no windows probably the main problem but that was for security reasons Link to comment Share on other sites More sharing options...
cruiser Posted May 28, 2012 Author Share Posted May 28, 2012 still not gotten round to trying anything with the speeds but its due to cool down at weekend so will have a try then Link to comment Share on other sites More sharing options...
