jbcontrol Posted March 5, 2021 Share Posted March 5, 2021 Hi all, i have sapphire decoder and wish to try and refit wires back onto it so i am looking for a picture of one which clearly shows colours and positions Thanks again for any assistance Link to comment Share on other sites More sharing options...
Rog RJ Posted March 5, 2021 Share Posted March 5, 2021 https://www.gaugemasterretail.com/magento/hornby-r8245.htmlAny good?Sapphires were a 21pin direct fit decoder that came with an adapter to allow them to be plugged into 8 pin sockets. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 5, 2021 Share Posted March 5, 2021 Rog's link made clickable.Digital Sapphire Locomotive Decoder with 8/21 Pin Adaptor-Hornby-R8245As Rog says the wires you can see in the link image are not soldered directly to the decoder. The decoder is natively a 21 pin decoder with a female header into which a male pin plug adapter cable is plugged to convert to 8 pin male pin NEM 652.The adapter cable is wired like this: Link to comment Share on other sites More sharing options...
96RAF Posted March 6, 2021 Share Posted March 6, 2021 This is the adaptor harness... Link to comment Share on other sites More sharing options...
jbcontrol Posted March 6, 2021 Author Share Posted March 6, 2021 Thanks for the quick replies. It seems that I have been cheated by someone as this decoder with some wires on is obviously not a Sapphire.Although upon further inspection maybe it is a Sapphire and someone had tried to solder wires on it.Is there a part number for a decoder harness and would it be out of production like the Sapphire.Thank you all very muchJB Link to comment Share on other sites More sharing options...
jbcontrol Posted March 6, 2021 Author Share Posted March 6, 2021 further to my last reply i have worked out that the wires were missing from the harness so have removed that part that was left on the decoder, then tested the decoder, which is unreadable even after telling the tester which decoder it is. so i have found out a lot by being on this forum and lost a decoder. thanks again to all JB Link to comment Share on other sites More sharing options...
Chrissaf Posted March 6, 2021 Share Posted March 6, 2021 Just for completeness of information. Hornby never sold the Sapphire harness on its own under a separate part number as an item available directly from Hornby. Link to comment Share on other sites More sharing options...
96RAF Posted March 6, 2021 Share Posted March 6, 2021 Sapphire ID in CV7 (or is it CV8) should be 10 if and when you can read it.It may well be an old ESU sound decoder fitted by Hornby to early factory sound locos.Although out of stock her is a source of the Sapphire adapter harness.https://www.strathpefferjunction.com/product/21-pin-to-8-pin-decoder-adaptor-board-wired-dcc-harness-with-nem652-8-pin-plug-sapphire/ Link to comment Share on other sites More sharing options...
jbcontrol Posted March 10, 2021 Author Share Posted March 10, 2021 thank you all for all the help. that is sorted and disposed of john Link to comment Share on other sites More sharing options...
