swany001 Posted March 12, 2021 Share Posted March 12, 2021 Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 13, 2021 Share Posted March 13, 2021 Start by trying the answer in the Jerky Start topic below, although this one sounds a little different. Link to comment Share on other sites More sharing options...
swany001 Posted March 13, 2021 Author Share Posted March 13, 2021 Thanks managed to resolve the issue some how my Bachmann dynamis speed steps had reverted to 28 changed it back to 128 and the issue has gone away completely Link to comment Share on other sites More sharing options...
RDS Posted March 13, 2021 Share Posted March 13, 2021 Moderator apology.Swanny001, I edited the title of your thread to Capitalise TTS and your entire post has been deleted. I did not touch your actual post but this is a problem, with the Forum Software.Would you mind editing your post to re-enter your question.Sorry.(My fellow Moderator Chris has found that when an edit to a 'Title' is required, if you make a small edit simultaneously at the same time within the main post content before clicking the 'Save' button, this overcomes the problem) Link to comment Share on other sites More sharing options...
Chrissaf Posted March 13, 2021 Share Posted March 13, 2021 Just to add in case you are unaware. You will find the 'Edit Post' option by clicking the three vertical dots in the top right corner of your post. This 'delete post content' bug has been reported to the forum developers and should be fixed in due course. Link to comment Share on other sites More sharing options...
96RAF Posted March 13, 2021 Share Posted March 13, 2021 Correct me if I am wrong but if one was to delete the original ‘empty’ post it will delete the whole thread, which is why it sits there question-less. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 13, 2021 Share Posted March 13, 2021 Correct. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 13, 2021 Share Posted March 13, 2021 Ignoring all this moderator chat swany, glad you fixed it. And yes, TTS needs 128 speed steps to work correctly. Link to comment Share on other sites More sharing options...
