grumpy old man Posted May 26, 2012 Share Posted May 26, 2012 HiI have just fitted an R8249 decoder to a Hornby R2763 loco it runs great both forward & reverse but I cannot alter the direction movement to fit in with my controller ie it runs forward when my controller button is pressed for reverse & visa versa. I have tried to alter the direction using both my elite & select & following the instruction manual both without success. Any help would be appreciated. Also why is the purple wire on the decoder loose & what is it for also do I have to cover the end of the purple wire with tape.Hope you can give me any adviceThanx Link to comment Share on other sites More sharing options...
Rog RJ Posted May 26, 2012 Share Posted May 26, 2012 You should be able to alter the normal direction by following the instructions in the user manuals. See page 12 of the Select manual or page 23 of the Elite manual.The purple wire is the fourth function output wire and as the decoder only has an 8 pin plug but 9 wires it is left loose and can be cut off or insulated to prevent short circuits Link to comment Share on other sites More sharing options...
poliss Posted May 26, 2012 Share Posted May 26, 2012 Your Select might have a newer version of firmware. HCC posted this a while ago."Changes to “default direction” switching Earlier versions of the Select allowed for the decoder to have the pre-set direction (default) changed by holding down one of the “Direction Arrow” keys for more than 3 seconds. However, it was possible to make accidental changes to the Decoder’s Default Direction when holding down a “Direction Arrow” key for too long when attempting to change a loco’s running direction. In Select version 1.2 the Decoder Default Direction is now set with a two key operation. This is now achieved by pressing and holding the “0” and one of the Direction Arrow buttons at the same time for 3 seconds." Link to comment Share on other sites More sharing options...
pidder Posted May 26, 2012 Share Posted May 26, 2012 From my experience, follow the instructions given by poliss above but you may have to do it several times to take effect.. Link to comment Share on other sites More sharing options...
grumpy old man Posted May 27, 2012 Author Share Posted May 27, 2012 Thank you everybody I have follwed the instructions and all is now Ok I will also isolate the purple wire.ThanxDon R(G O M ) Link to comment Share on other sites More sharing options...
